Author Topic: Alt-click on Debian/LXDE  (Read 27294 times)
Offline buserror
« on: March 13, 2015, 12:33:13 pm »
I've disabled the alt-click drag move of OpenBox as stated there: http://forum.lxde.org/viewtopic.php?t=1189&f=8
however, I can't rotate in Cambam, anyone tried it?
And no, the other methods for rotating won't work for me, I don't use a 'mouse' on the computer so I can't click multiple buttons at once...
Is it really hard to add other options to rotate? like, in any other programs? Dunno, shift-click, or space bar, or whatever? or even --god forbid-- a 'rotate view' tool?
Offline llamatrails
Re: Alt-click on Debian/LXDE
« Reply #1 on: March 13, 2015, 13:00:02 pm »
I second the request.
Same issue here, even with the mouse, both in Debian and Ubuntu.  The alternates in Tools-Options don't work on either, Left+Middle and Left+Right.  Even tried to disable the Alt key in linux, but it seems to be impossible.  Sigh.
Rick
TIA,
Rick
« Reply #2 on: March 13, 2015, 13:48:28 pm »
Is this any use ? http://www.cambam.info/ref/plugin.viewtoolbaraddins
it has an ISO view that might do.
Offline llamatrails
« Reply #3 on: March 13, 2015, 20:09:30 pm »
Yes, it does.  Thanks for pointing it out !!!!
Rick
TIA,
Rick
« Reply #4 on: March 13, 2015, 20:33:03 pm »
Just out of interest, do all/most plugins and scripts work in the Linux version ?
Offline llamatrails
« Reply #5 on: March 14, 2015, 00:55:10 am »
Yes, the only issue I've had has been the darn ALT key being grabbed by the window manager.  I run it on Ubuntu and the Debian linuxcnc realtime kernel.
TIA,
Rick
« Reply #6 on: March 14, 2015, 13:58:54 pm »
Try this  ;D
Edit: I'm trying to grab a few minutes here and there with a house full of people so I completely forgot the fact that the Alt key was a problem, I'll change it  :P
This incorrect version now removed, please use the version below.
« Last Edit: March 15, 2015, 08:36:27 am by EddyCurrent »
« Reply #7 on: March 14, 2015, 16:31:32 pm »
Right this might be better;
Keys are;
Shift + Z  rotate Z+
Shift + X  rotate X+
Shift + C  rotate Y+
Shift + A  rotate Z-
Shift + S  rotate X-
Shift + D  rotate Y-
« Last Edit: March 14, 2015, 16:37:23 pm by EddyCurrent »
Offline llamatrails
« Reply #8 on: March 14, 2015, 17:16:35 pm »
Yow, this works very well on Ubuntu 14.04 . I'm fine with the key combinations, they should be easy to remember.
Thanks!!!
TIA,
Rick
« Reply #9 on: March 14, 2015, 17:26:49 pm »
Excellent, I used keys that were close together to make life easier.
« Reply #10 on: March 15, 2015, 10:30:05 am »
No, but it's not often anyone has a problem with it, maybe you still do ?
Offline llamatrails
« Reply #11 on: March 17, 2015, 17:40:18 pm »
Minor issue:  I went to type in an Out File name with a capital A and the part rotated.   ::)
TIA,
Rick
Offline macbob
    • Bob Mackay
« Reply #12 on: March 17, 2015, 22:30:13 pm »
Reminds me of the text editor where if you typed "FALSE" while not in insert mode, the "F" did nothing, the "A" selected all the text, the "L" replaced the selected text with an "L", the "S" saved the file and the "E" exited...
Offline buserror
« Reply #13 on: March 18, 2015, 19:06:43 pm »
BTW, I downloaded the plugin but the plugin menu shows me 'plugin disabled' so I guess that's why the keypresses aren't working :/
Tried to find an 'enable plugins' setting but nothing jumps to my attention...
Thanks for taking the time tho...
« Reply #14 on: March 18, 2015, 19:18:55 pm »
You are correct, I thought once the drawing view lost focus it would not happen, but I can see it does, maybe needs a rethink on the keys but there's not much choice left.
