Author Topic: Alt-click on Debian/LXDE  (Read 25341 times)
Re: Alt-click on Debian/LXDE
« Reply #15 on: March 18, 2015, 19:20:25 pm »
BTW, I downloaded the plugin but the plugin menu shows me 'plugin disabled' so I guess that's why the keypresses aren't working :/
Tried to find an 'enable plugins' setting but nothing jumps to my attention...
Thanks for taking the time tho...
There's nothing special about this plugin so I imagine you have the same issue with all of them ?
Offline buserror
« Reply #16 on: March 18, 2015, 19:33:21 pm »
Yes, none are listed in the menu in any case. There must be something about 'mono' the .NET VM thing.
Offline llamatrails
« Reply #17 on: March 18, 2015, 23:02:55 pm »
Plugins are disabled in Linux unless you have a license.  They do work in Windows when in the trial period.
See the comments near the bottom of http://www.cambam.info/ref/ref.linux .
TIA,
Rick
Offline manymachines
« Reply #18 on: March 21, 2015, 01:36:42 am »
I've just started evaluating CamBam using Ubuntu 14.04.
The instructions here don't currently mention 14.04.
Anyway the 12.02* method worked for me except I changed the "mouse-button-modifier" to:
<Control><Alt>
Now Alt rotates in CamBam.  Holding both Ctrl and Alt drags a window.
Offline llamatrails
« Reply #19 on: March 21, 2015, 14:41:24 pm »
Brilliant!!!  Great find, this is what the forum is all about. ;D
TIA,
Rick
« Reply #20 on: March 21, 2015, 15:26:51 pm »
Yes it is good. Because I don't use Linux it never occurred to me that a solution might already exist.
Is it fair to say now that the plugin I did is not required now ? if so that's great because the key combinations can be used for something else.
Offline llamatrails
« Reply #21 on: March 21, 2015, 22:59:09 pm »
All your work isn't for naught, the OP doesn't use a mouse.  I like the incremental movement with the keyboard, so I will be using both.  Thanks again.
TIA,
Rick
