Author Topic: [Engraving] - Gaz (Joe Bar Team)  (Read 40699 times)
Re: [Engraving] - Gaz (Joe Bar Team)
« Reply #15 on: June 16, 2015, 15:28:30 pm »
@Eddy: Maybe you forgot the accent ;)
Couche = Layer
Couché = Lying down
It's a great plugin that CBubble   ::)
sure  ;D
Ok, I just wrote a little script to select CW or CCW and after remove the one or the other I obtain a nice file without other job to do  ;D .. (but spline to polyline is very long)
after this first cleaning, I use dave's plugin to remove open/closed poly <= 4mm perimeter.
before converting spline to poly, is set the tolerance (option) to 0.1mm .. that give a very nice result
' select CW/CCW polylines
' dh42 06/2015
sub main
'ask for CW/CCW
dim rep as string
dim p as polyline
CamBamConfig.Defaults.ReloadTreeAfterScript = false
rep = inputbox("1 - Select CW " & vbnewline & "2 - Select CCW ",, 1)
if rep <> 1 and rep <> 2 then exit sub
dim newselection as ArrayList = new ArrayList()
if view.SelectedEntities.Length > 0 then
if typeof ent is Polyline
p = ent
if p.closed = true 'only if closed polyline
select case rep
case 1 'CW
if p.direction = -1 then
newselection.add(ent)
end if
case 2 'CCW
if p.direction = 1 then
end if
end select
end if
end if
next ent
view.Select(newselection)
view.RefreshView()
end if
end sub
« Reply #16 on: June 16, 2015, 15:31:56 pm »
re
And just another little script to count how many drawing objects are selected  ;D
' count selected
sub main
dim ct as long
Dim ent As Entity
    For Each ent In view.SelectedEntities
            ct = ct+1
        Next
app.log(ct & " Objets sélectionnés")
end sub
« Reply #17 on: June 18, 2015, 13:14:26 pm »
HI David
I've been playing around with Inkscape and have found a to produce a file with no splines just lines which
are quick to work with. I have started from a jpeg and imported it into Inkscape processed it and then exported
it and loaded it up in CB ran the polyline doctor over it and then generated a engraving file and simulated
I was surprised at how quick this was to produce perhaps 5 seconds for a file of 1meg.It's late now so in the morning I'll do the same thing with the image file you posted and see if that works fast to.
Dave.
« Reply #18 on: June 18, 2015, 13:57:39 pm »
Hello Dave,
I wonder what's taking so long to convert a spline to a polyline.
I wrote a little script that count the points in a spline. (and creates a point list).
for a spline that contain 433 points, the conversion to polyline takes 15s !! (the test spline + vbs are in attachment)
« Reply #19 on: June 20, 2015, 18:58:31 pm »
hello,
2 new conversions
Use a V-cutter with a flat tip = 0.3/0.4mm
the results with CV
If you want to cut it with a smaller size (approx 200x200mm), use an engraving operation instead of a pocket operation.
DXF and CB file in attachment.
Offline klystron
« Reply #20 on: June 21, 2015, 14:12:08 pm »
salut !
conversion de fichier en ligne :
http://www.autotracer.org/
a+
« Last Edit: June 21, 2015, 14:16:20 pm by klystron »
« Reply #21 on: June 21, 2015, 23:40:42 pm »
I went and had a look at the web site klystron and they also have a stl converter as well but I noted that the file size was limited to 1mb could be handy.
Davis I think the splines and associated functions are just dealing with more data and having to convert between types is adding to the time taken.
