However, I have made clean, unburred holes in gasket material with my CNC. You do 'drill' them, at a very low rpm, using a hollow hole punch, not a drill or a mill.
They come out perfectly smooth and sharp-edged, if you use the sort of punch tapered on the inside, rather than on the outside. (In other words, a "hole" punch, not a "disc" punch.) Lloyd
Good suggestion Lloyd. I do have the outside tapered disc punches, but as you say, they will break out an ear if not punched before the profile is cut. I could easily make myself some hole punches/cutters in several sizes, but I dont have a low spindle speed option. Still, they might come in handy as a manual punch. They are surprisingly hard to find.
Small holes do cut very well with spiral flute router bits with a spiral lead in, and also the type of drill bit similar to a brad point with the raised outer cutting edge. If the need arises for small holes in thicker stock, those may be the my only options. They all do create vacuum leaks in the hold down table. The knifed hole interiors stay put (most of the time).
For now, I'm trying to get by without tool change so I can cut many (nested) features in an unattended fashion and without secondary OPs.
The old school production method was steel rule dies and presses. Remember those?
Best,
Kelly
