Author Topic: Collision Detector+Clean up Mops  (Read 34392 times)
« on: June 23, 2015, 02:17:33 am »
HI all
Here is a fork of the Collision Detector with clean up mops.
In the zip file are 5 files. A .dll to pop in your plugins directory, a manual in pdf form and three tutorial .cb files
to help get you started and are used in the manual.
I'll put the manual here in pdf form so you can quickly see if it may be useful for you.
Dave.
New File Update found problem with some shapes throwing an exception in new dictionary function.
New Version 100% faster inside tool paths 50 % faster overall , warns for regions handles more shapes.
New version 1.3 + added doing text to the tutorial along with a .cb tut file
New version 1.3 data + handles more shape cases faster toolpathing for inside offsets extra example file.
warns for Mtext.
New Version handles open polylines adds Styles and Custom Styles (Inside Tool Paths Slower but more robust)
Dave.
Fixed spelling mistakes and a Cb file for the tut.
Fixed style library discovery method for other versions of windows
Fixed Duplicate libraries added to checkboxes when changing libraries
Fixed duplicate entries when selecting regions.
« Last Edit: September 09, 2015, 23:00:06 pm by dave benson »
Re: Collision Detector+Clean up Mops
« Reply #1 on: June 23, 2015, 19:38:20 pm »
It is a very useful plugin I think ;) but not too much time to do tests currently ..
It works on Linux version but the choice for the background color of the UI is a problem on Linux ; texts are unreadable (see the screen capture)
« Reply #2 on: June 23, 2015, 21:07:22 pm »
HI David
Thanks for info , I did not realise what it would look like on Linux.
I'll post another file with the standard colours later today for you look at, and if that looks alright
I'll change the one in the zip file.
« Reply #3 on: June 23, 2015, 21:42:23 pm »
Hi David
Try this when you get time and see if it is ok for Linux.
edit replaced file, Use  file at first post re: dictionary bug and changed colours for linux.
« Last Edit: June 24, 2015, 00:11:50 am by dave benson »
« Reply #4 on: June 24, 2015, 07:13:50 am »
Dave,
It looks like you did something with the code, only one line was out of place this time but it was easily corrected by reversing the polyline.
I know this part is difficult due to the fact that people's setup will vary, but because there was no 'Tool Number' entered, there was no tool change command generated in the g-code.
The fact that the small clean up tool is only going to cut the sections that need it is really excellent.
« Last Edit: June 24, 2015, 07:26:56 am by EddyCurrent »
« Reply #5 on: June 24, 2015, 11:38:38 am »
HI Eddy
Yeah its getting better but I discovered that it throws an exception with some regions, so I've fixed it  so that it now warns you to convert to polylines, and have kept testing on some other files, and there always seems to be something else for example I was doing some Mtext and it went well except for the text was offset about a third of it's height so I think it's got something to do with the margin at the top and bottom of the text and because each font has different spacing I'll have to find out what the spacing is for each and I'm not sure how to do this.
I'll keep plugging away at it tonight and post an updated file tomorrow.
« Reply #6 on: June 24, 2015, 12:09:25 pm »
HI Eddy
I had similar issues with the 'Text on Polyline' plugin, the source is there if you want to check it out, I used MText for that.
Roughly what I did was position a letter at 0,0,0 then using GetExtents, measured the offsets from X and Y, however the kerning of letters varies with combinations and font size, so you have to be a bit more crafty sometimes. It took a lot of thinking about before I got to an answer that satisfied me, anyway it's all in the source code for that plugin.
« Last Edit: June 25, 2015, 10:13:21 am by EddyCurrent »
« Reply #7 on: June 24, 2015, 17:57:05 pm »
It's a little better, but remain difficult to read (at least for me)
« Reply #8 on: June 24, 2015, 22:40:06 pm »
HI Eddy
Thanks for the reply and I'll definitely look at your text on a polyline code.
David is there a plugin that looks good on Linux  so I can have a look at the colours, it appears that the text itself looks washed out in Linux  but on windows it is black.
« Reply #9 on: June 24, 2015, 23:09:48 pm »
The wrapper plugin
http://www.atelier-des-fougeres.fr/Cambam/Aide/Plugins/Wrapper_plugin.html
« Reply #10 on: June 25, 2015, 07:22:34 am »
When I looked at recommended colour combinations, yellow and white were the best backgrounds for grey text.
David, is the text grey on all Linux systems or is it just your personal settings ?
« Reply #11 on: June 25, 2015, 07:51:43 am »
HI David and Eddy
I've just uploaded a New Version, 100% faster inside tool paths 50 % faster overall , warns for regions handles more shapes. I've also changed the text colour to Black from the windows "System Control Text" option
which may be better to see. over the weekend I'll check out the text issues.
Dave.
« Reply #12 on: June 25, 2015, 13:34:16 pm »
I don't know ; I'm not a Linux user, I install it (with difficulty) only to be able to test CamBam and the plugins (ubuntu) and I never use it for other things  :) ... I do not even know how to change the background or font color on Linux  :-[
I test later the new version of the plugin, I have to go to work ..
« Last Edit: June 25, 2015, 13:35:51 pm by dh42 »
« Reply #13 on: June 25, 2015, 21:58:39 pm »
Ok for the colors on Linux ;)
« Reply #14 on: June 26, 2015, 03:37:40 am »
HI David
I'll apply those colour prefs to the rest of the form and keep doing that from now on.
I'll post an update tonight (just running a test on the mill now for text) the "N" from webdings font, the Jolly Roger.
Cut the pocket with a 6mm cutter, Profile with a 3mm cutter (looks good) so far,  and now have to grind up a 0.5 mm cutter from a used engraving tool. wish me luck :)
