Author Topic: CamBam plus 0.9.8P (latest stable release)  (Read 32351 times)
« on: September 22, 2015, 09:37:41 am »
CamBam version 0.9.8 rev P is now the official 'latest stable release'.
http://www.cambam.info/downloads/
This is basically the 0.9.8P-beta release that has been under 'extended' testing.
A list of the changes in the 0.9.8P release can be found here:
http://www.cambam.info/doc/plus/WhatsNew.htm#p
Thank you for your patience with this one!
Andy Payne
Re: CamBam plus 0.9.8P (latest stable release)
« Reply #1 on: September 30, 2015, 16:09:11 pm »
A little clarification for the installation of this version P.
You must delete the CamBam installation folder before installing version P
(C:\Program Files\CamBam plus 0.9.8 for 32bit systems, or C:\Program Files (x86)\CamBam plus 0.9.8 for 64bit systems) .
If you have already installed CamBam without deleting this folder, you can delete it and reinstall/repair CamBam.
Remember to save your license file before deleting the folder CamBam plus 0.9.8 (file: CamBamPro.lic)
If this CamBam plus 0.9.8 folder is not deleted before installation, Python scripts will not run.
and you will obtain the following error in the message window.
Failed to load language IronPython 2.7.5 .....
« Last Edit: September 30, 2015, 16:13:01 pm by dh42 »
Offline Lou van Wijhe
    • Lou's Homepage
« Reply #2 on: October 04, 2015, 18:12:36 pm »
Hi David,
I'm confused about the 32-bit or 64-bit capability of CamBam. How can I check this? You wrote:
(C:\Program Files\CamBam plus 0.9.8 for 32bit systems, or C:\Program Files (x86)\CamBam plus 0.9.8 for 64bit systems).
Isn't this the other way around? In 64-bit Windows PCs there is a dual software folders structure, i.e. "Program files' for 64-bit software and 'Program files (x86)' for 32-bit software. 32-bit software programs, by default, install to the 'Program files (x86)' folder.  This is to minimise or eliminate the risk of having both 32-bit and 64-bit installs of the same program present, and their installation files creating conflicts and/or performance problems. All this according to Microsoft.
On my 64-bit system CamBam installed to the "Program files (x86)' folder. If CamBam is 32-bit, this is correct. Isn't it?
Lou
« Reply #3 on: October 04, 2015, 18:59:57 pm »
Yes, correct ; there is only a 32bit version of cambam for Windows and it is installed by default in the "Program files (x86)" folder
Offline topduck
« Reply #4 on: October 08, 2015, 17:10:25 pm »
Hi
Is the new version free for people already bought older version, or is it an upgrade or do we have to buy it again.
Your message only say it is a limited time use and then the code will be restricted to 1000 lines only ..
Please clarify.
Thanks
« Reply #5 on: October 08, 2015, 18:08:55 pm »
Hi
Please clarify.
Thanks
If you are owner of CamBam registration number then don't need to buy anything. Just download and install the upgrade. The upgraded version will find the registration number automatically.  ;) ;D
Offline topduck
« Reply #6 on: October 08, 2015, 18:29:24 pm »
Thanks Bubba
Offline HREFAB
« Reply #7 on: November 22, 2016, 13:54:35 pm »
Is there or has there been any activity on CAMBAM in the last 12 months, or can we assume that 0.9l9P is the final iteration?
« Reply #8 on: November 22, 2016, 14:05:59 pm »
Yes there has been activity, a new version is currently in alpha testing, I don't have an expected release date for it.
Offline cambam30
« Reply #9 on: November 25, 2016, 15:54:51 pm »
Why not make the debugging public?
« Reply #10 on: November 25, 2016, 16:31:36 pm »
I expect it will be public when it moves into beta testing.
Offline HREFAB
« Reply #11 on: November 25, 2016, 20:29:06 pm »
Ahhh! What GREAT NEWS! I have been suffering CAMBAM UPDATE Withdrawal syndrome!
The CURE is in sight!
Thanks!
« Reply #12 on: November 25, 2016, 20:46:59 pm »
But have you been keeping up to date with plugin development ? http://www.atelier-des-fougeres.fr/Cambam/Aide/Plugins/plugin_menu.html
« Last Edit: November 25, 2016, 21:58:54 pm by EddyCurrent »
« Reply #13 on: November 25, 2016, 21:54:31 pm »
Right, It's what Andy tell me.
