Author Topic: [script] remove points closest to the given value  (Read 2908 times)
« on: September 24, 2015, 20:03:19 pm »
This script is designed to remove points closest to the given value in a polyline.
it's an experiment to clean the polylines that results of a picture digit (to remove the stairs)
   ' remove points closest to the given value
    Sub main()
        Dim rep As String
        Dim tol As Double
        Dim p As polyline
        Dim nbpt1 As Integer
        CamBamConfig.Defaults.ReloadTreeAfterScript = False
        rep = inputbox("Max distance between 2 points", , 0)
        tol = val(rep)
        If CamBamUI.MainUI.ActiveView.SelectedEntities.Length > 0 Then
            For Each ent As Entity In CamBamUI.MainUI.ActiveView.SelectedEntities
                If TypeOf ent Is Polyline Then
                    p = ent
                    CamBamUI.MainUI.UndoBuffer.AddUndoPoint("RemovePoints")
                    CamBamUI.MainUI.UndoBuffer.Add(ent)
                    nbpt1 = p.Points.Count
                    If p.RemoveDuplicatePoints(tol) = True Then
                        App.Log("Polyline: " & ent.ID & "  #Points before: " & nbpt1 & "  #Points after: " & p.Points.Count & "  #Points removed: " & nbpt1 - p.Points.Count)
                    End If
                    p.Update()
                End If
            Next ent
            CamBamUI.MainUI.ActiveView.RefreshView()
        End If
    End Sub
« Last Edit: September 24, 2015, 20:04:55 pm by dh42 »
