Author Topic: CamBam to CAMotics export  (Read 10084 times)
Offline jk
« on: October 13, 2015, 13:07:13 pm »
Hello !
Here is a quick and dirty script to I wrote to export g-code from CamBam into CAMotics (open source cut simulator).
Basically, script is creating CAMotics project xml with a link to g-code + embedded tooltable of used tools + stock definition.
Anybody want to give it a try  ?
« Last Edit: October 13, 2015, 20:20:07 pm by dh42 »
Re: CamBam to CAMotics export
« Reply #1 on: October 13, 2015, 13:18:28 pm »
Welcome to the forum !
A script that will be usefull for some, I think ;D
« Reply #2 on: October 13, 2015, 13:51:02 pm »
Hum !! I tried it but there is something that I don't understand in Camotics.(I attach a CB file + Gcode + xml)
The XML seems to contain the correct values for tools and stock, but when I open the Gcode in camotics, it seems that the xml file is not read ; no tools/stock appears in the tree at the left side  (and there is errors in the log windows) ...
What post pro we must use ... I tried Mach3-CV, LinuxCNc and Default ; same result  ???
PS: I don't know camotics, it my first use ..
« Reply #3 on: October 13, 2015, 14:23:16 pm »
More tests ....
- The xml file is read and tools and stock are set in camotics if I change the extension from  xxxx.nc.xml to xxxx.xml ... but ... in this case the Gcode is not read and I must open it separately.
- for this second problem, it's in the XML file ; the gcode name must be alone, without the filepath
ex:
camotics>
    <nc-files>
        C:\Program Files\CAMotics\examples\testcamotics.nc
    </nc-files>
with the previous code, the Gcode is not read
camotics>
    <nc-files>
        testcamotics.nc
    </nc-files>
and that works with this code ;)
small details to solve, but it's a nice job, congratulations
Offline jk
« Reply #4 on: October 13, 2015, 14:33:13 pm »
Thank you )
Looks like CAMotics is failing to parse whitespaces in filename (even for own-generated xml :)
As a quick fix, I am replacing all spaces with %20 and it's working now. Please see updated version.
« Last Edit: October 13, 2015, 20:20:32 pm by dh42 »
« Reply #5 on: October 13, 2015, 14:56:34 pm »
Ok, that fix the Gcode loading problem.
The extension problem with the XML file remain (*.nc.xml)
« Reply #6 on: October 13, 2015, 17:46:35 pm »
Here you effort is much appreciated. It certainly be nice to have free decent simulator.
During 'test drive' of your script a following message appeared.. Figured it maybe of some help to you.. Win 10 OS and the latest CamBam..
Offline jk
« Reply #7 on: October 13, 2015, 18:08:34 pm »
Now I understand the extension problem. The supposed way to use CAMotics is to open xml project, not gcode file.
If one trying to open g-code, CAMotics tries to find matching .xml behind the scenes and opens it instead )
I've changed script to make .xml have a same basename as .nc file. There is a new version attached.
Bubba, looks like Python is not working at all at you installation. Try to execute a default blank python script (Script->New->Python Script. There should appear 'Hello' in console.
« Reply #8 on: October 13, 2015, 18:10:48 pm »
Bubba, look here if that can solve your problem ;)
http://www.cambam.co.uk/forum/index.php?topic=5121.msg40528#msg40528
« Reply #9 on: October 13, 2015, 18:16:31 pm »
Ok, work for me ;)
EDIT: I removed the old versions of the script in your messages ;)
« Last Edit: October 13, 2015, 20:23:05 pm by dh42 »
« Reply #10 on: October 14, 2015, 00:02:33 am »
Thanks David, That did the trick.
Offline jcoffland
  • CAMotics creator
« Reply #11 on: October 15, 2015, 18:10:00 pm »
CAMotics creator here.  I cannot see the CamBam parsing part of the cb2cm.py script, i.e. the helpful part.  I don't have the CamBam Python libraries.  Reading CamBam tool tables is on my to do list.  Here's the GitHub issue: https://github.com/CauldronDevelopmentLLC/CAMotics/issues/71
I'm glad to see the CamBam crowd is interested in CAMotics.  Global tool tables and units settings are high on my priority list.
Please do consider sharing projects on our new site http://buildbotics.com/
« Reply #12 on: October 15, 2015, 18:18:36 pm »
You can download and install CamBam without buying it.  It is 40 executions limited in demo mode.  That can be days or months or possibly even years depending on how you use it.  After 40 uses its 1000 lines of code output limited.  1000 lines should be enough to test any compatibility issues.  Its primarily developed fr Windows, but there is a Linux version as well.  Also, if you want to persue active interoperability with CamBam you might be able to do some coordinating with Andy.  Even if he is too busy there are some really good script writers here among the users.
« Reply #13 on: October 15, 2015, 18:32:28 pm »
Welcome Joseph ;)
Hum, Bob, after 40 uses, not only the Gcode is limited to 1000 lines but the plugins and scripts no longer works....
« Reply #14 on: October 15, 2015, 18:35:29 pm »
Joseph, these links might throw some light on scripts etc.
http://www.cambam.info/ref/script
http://www.cambam.info/ref/plugin
http://www.cambam.info/doc/api/CreatingAPlugin.htm
And there are source code files here for scripts and plugins;
http://www.cambam.co.uk/forum/index.php?board=6.0
Is there a plugin interface for CAMotics ?, I looked at the source code but it seemed there was not.
« Last Edit: October 15, 2015, 18:38:11 pm by EddyCurrent »
