Author Topic: Does Fillet-Chamfer plugin still working in 'P'  (Read 4944 times)
« on: December 11, 2015, 13:51:22 pm »
Hi All,
Does Fillet-Chamfer plugin still working right in CB with the newest release? I cannot do anything with it it doesn't matter if the polylines are closed/exploded, etc. Changed the radius value to minimum hoping it was the problem.. No joy!
OS Win10
CB  CamBam plus [0.9] Rel 8P
Copyright © 2015 HexRay Ltd
Re: Does Fillet-Chamfer plugin still working in 'P'
« Reply #1 on: December 11, 2015, 21:18:37 pm »
I got it working.. again. Restarted CamBam opened the file and it works!  ??? ;D ???
« Reply #2 on: December 11, 2015, 21:27:31 pm »
Lol, stay on XP  ;D, all works well on it !!
« Reply #3 on: December 12, 2015, 01:31:23 am »
 ;D
« Reply #4 on: December 12, 2015, 17:42:22 pm »
Win7 and CB version P
The plugin don´t work with this file, with my own files it works.
Only if I drag the nodes of the object a little bit, after the plugin works.
bizarre behavior
« Reply #5 on: December 12, 2015, 18:26:51 pm »
Sorry, I've not seen the .cb file.
I do a test ... and same on XP ; the pb is because the polyline must be flat and at z=0.
you can use my flatten plugin to correct the polyline.
http://www.atelier-des-fougeres.fr/Cambam/Aide/Plugins/flatten.html
