Author Topic: file problem arcs  (Read 25560 times)
Offline michel
    • het-trappenatelier
file problem arcs
« on: January 27, 2016, 20:51:12 pm »
Hi ,
I am trying to run a small file with arc content . Drawing was made in autocad is is nothing different from my other drawings . When loeding this one cb  sees all arcs as invalid and cb ultimately stop running and act weird . Like is not coping with the arcs . I tried to redraw arcs but this is not even hapening. File Attached . I hope someone can assist here
original dxf file also added . only 1 part of the dxf is used and that is in the cb file
Re: file problem arcs
« Reply #1 on: January 27, 2016, 21:01:53 pm »
In Autocad, you must export your DXF to Autocad2000 (AC1015) or autocad R12 (AC1009) format.
Your file is saved in Acad 2007/2009 (AC1021) Cambam can't read it.
« Reply #2 on: January 27, 2016, 21:04:18 pm »
CamBam doesn't like dimensions either, I opened it in Rhino, removed dimensions then saved.
« Last Edit: January 28, 2016, 08:53:10 am by EddyCurrent »
Offline michel
« Reply #3 on: January 27, 2016, 23:42:48 pm »
Hi ,
this remains a problem even if i save on autocad 2000 . The arcs are invalid and not imported
the file from eddy imports the arcs but with a large qty of points which i did not had in the autocade drawing and arcfit doesnt help there . Why do I have problems on that file ? Every other file was also 2007 and worked fine?
it seems only arcs are creating problems
« Reply #4 on: January 27, 2016, 23:57:55 pm »
No idea ... I can't open your file nor in SolidWorks(2008), Illustrator(CS3) or Autocad(2002) ...
Offline michel
« Reply #5 on: January 28, 2016, 00:05:41 am »
what is different on this file ? this one is working in cb and is 2007 dxf ?
Offline michel
« Reply #6 on: January 28, 2016, 00:16:02 am »
i see that the file from eddy is changing the arcs to a 2dpoly instead of an arc ? The file i just send is an arc saved in version 2007 and working in cb. Very strange all my drawings are in 2007 and working
« Reply #7 on: January 28, 2016, 00:22:02 am »
Re
If I open Eddy's file on CB, no pb but if I try to 'insert arcs' in one of the ray of the "galaxy", I get the same 'invalid arcs' error and CB do strange things.
If I select all, then "center extent", this pb go out ... maybe a size limit in CB .. (your arc are at X=209000 and Y = -30153
Maybe try to set the origin at a more suitable position in Acad.
Offline michel
« Reply #8 on: January 28, 2016, 00:29:38 am »
Hi David
thx it is working .  ;D
indeed a size limit
« Reply #9 on: January 28, 2016, 00:35:07 am »
Yes, I do a simple test, I draw an arc in CB, then convert to polyline and remove arcs, the I set the arc at 209000 in X ... and same pb if I 'insert arcs' .. after some tests, it seems that the limit is ~ -100000 to +100000 ...
Offline michel
« Reply #10 on: January 28, 2016, 00:47:24 am »
Hi David
thx
are you familiar with the plug-in automated mop ? I do not find the detailed info on this one
« Reply #11 on: January 28, 2016, 00:58:12 am »
I don't know such plugin ... are you sure it's the right name ?
there is something called Mop Automate, but it's not a plugin but a bunch of example codes to write a script/plugin.
http://www.cambam.info/ref/script.mop-automate
Offline michel
« Reply #12 on: January 28, 2016, 01:20:59 am »
yes that is the one so it is not a finished version i can use then .
thx
