Author Topic: Box Auto Plugin  (Read 17738 times)
Box Auto Plugin
« on: January 31, 2016, 21:22:22 pm »
This plugin is a collaborative job with speedjf37, initially based on the old "doll house" script from Andy (crenelated boxes)
It is intended to simplify the creation of various crenelated boxes.
http://www.atelier-des-fougeres.fr/Cambam/Aide/Plugins/BoxAuto.html
the original French topic is here
http://www.usinages.com/threads/script-boites-crenelees.80494/
Re: Box Auto Plugin
« Reply #1 on: January 31, 2016, 22:37:11 pm »
Re
@Ralf: The Photoshop file of different boxes types for your website, so you can just edit the texts ;)
Re: Box Auto Plugin
« Reply #2 on: February 01, 2016, 10:40:00 am »
Nice plugin  ;D I like the comments layer.
I see there was mention of dégagements des angles, it looks like you have to add a profile MOP yourself and remember to set that. What about if the plugin added a profile MOP ?
« Last Edit: February 01, 2016, 11:20:18 am by EddyCurrent »
Re: Box Auto Plugin
« Reply #3 on: February 01, 2016, 13:08:41 pm »
Nice plugin, David. Thanks..
Re: Box Auto Plugin
« Reply #4 on: February 01, 2016, 21:23:46 pm »
The major job has been done by JF ; I just add translation code and small details .. ;)
Re: Box Auto Plugin
« Reply #5 on: February 01, 2016, 21:26:00 pm »
OK, then, Thanks to both of you.. ;) ;D
Offline billt
Re: Box Auto Plugin
« Reply #6 on: February 02, 2016, 14:04:08 pm »
Nice work!
I have been thinking about something similar, for kitchen cabinet drawer bodies.
For this application, the drawer sides would be 3/4" solid wood, or plywood with edge banding on the top edge.
The bottom would be 1/4" or 3/8" plywood captured in a groove.
The box joints would be a "hidden box joint" so the joint is not visible from the sides, they would be covered by the drawer front.
This is accomplished by making a partial-depth cut on the side pieces, and a corresponding notch height on the front/back pieces.
Other useful features would be holes for the drawer pull, and notches in the back for blum bottom-mount drawer slides.
Any interest in adding this to the plugin?  I can help out with the details.
Cheers - BillT
Re: Box Auto Plugin
« Reply #7 on: February 02, 2016, 20:52:25 pm »
You can show a picture ? I don't understand .. and also Goggle won't translate "blum"
Re: Box Auto Plugin
« Reply #8 on: February 02, 2016, 21:08:14 pm »
Re: Box Auto Plugin
« Reply #9 on: February 02, 2016, 21:14:31 pm »
thank you for the photoshop file. I will finish the translation at weekend.
As I've already written I want to put subdivisions on the wishlist. ::)
Re: Box Auto Plugin
« Reply #10 on: February 02, 2016, 22:04:59 pm »
http://www.blum.com/us/en/
Ah yes ! .. I had not thought that the boxes can also serve as drawers !!  ;D
Maybe JF will hear you ;) (I returned him the source code after I've added the translation code)
Offline TJ47
Re: Box Auto Plugin
« Reply #11 on: February 06, 2016, 07:35:04 am »
Very nice plugin, useful as it is...
Thanks
Tony...
Re: Box Auto Plugin
« Reply #12 on: February 06, 2016, 23:06:41 pm »
a new version is available (1008) that fix some bugs in reduced front boxes and also position of the lines for the sliding cover (too much clearance)
« Last Edit: February 06, 2016, 23:09:16 pm by dh42 »
Offline speedjf37
Re: Box Auto Plugin
« Reply #13 on: March 09, 2016, 21:58:17 pm »
Hi  BillT,
Nice work!
Cheers - BillT
Sorry it's to spécific
JF
Re: Box Auto Plugin
« Reply #14 on: March 09, 2016, 22:13:46 pm »
JF,
Are you joking? (I hope!)  "Hidden box joints" are a very common assembly method, and not at all "too specific" if included in a routine designed to make box joints!
