Is it normal that the file requester ask for a file name for each "part" instead of using the name of the part added to the file name ? (it propose the name of the CamBam file without adding the name of the part as when we produce Gcode for a part only)
ex: my file is called: Gcode_part_test, and the plugin propose the same name for the part instead of Gcode_part_test.part1, Gcode_part_test.part2, etc ...
When I use it with 2 parts, it give me a warning when saving the second part because it use the same name than for part1 (file already exist, overwrite ?), and I must click NO, then enter a new name for each part..
