Author Topic: Drawing an Ellipse  (Read 10271 times)
Drawing an Ellipse
« on: May 10, 2016, 22:47:15 pm »
I recently had cause to draw an ellipse in CB.  At one time (2008) there was an ellipse plugin, but I don't see it on the plugins page.  However it's pretty simple to do in CB itself.
1) Draw a circle whose diameter is the major axis length
2) Convert circle to a polyline
3) Apply the remove arcs edit to the polyline
4) In the transform window, apply the scale transform to either the X or Y axis.  The scale amount is the ratio of the minor to major axes.
Re: Drawing an Ellipse
« Reply #2 on: May 11, 2016, 07:02:06 am »
It must have slipped your mind, it was in CAD Extras; http://www.cambam.info/ref/plugin.cadextras
but has now been integrated into CamBam.
I do like the method you describe for drawing one.
Ellipse is here;
« Last Edit: May 11, 2016, 12:23:54 pm by EddyCurrent »
« Reply #3 on: May 11, 2016, 11:31:30 am »
My mind does slip a lot these days.   ???  I do most of my CAD work outside of CB and rarely look at the CAD extras,
« Reply #4 on: May 11, 2016, 11:48:11 am »
It slip my mind as well ;D. I didn't bother to look there Eddy.. :D
« Reply #5 on: May 11, 2016, 18:01:42 pm »
 ;D ;D
And there is also 2 scripts called elipse.py and elipse.vbs that are installed at the same time as cambam for ages,  ;)
