Author Topic: Installing plugins  (Read 7788 times)
Installing plugins
« on: August 25, 2016, 23:14:18 pm »
I moved some new plugin DLL files into the plugins folder but don't see them in Cambam. Is there a step I missed?
Re: Installing plugins
« Reply #1 on: August 26, 2016, 00:36:36 am »
No, just restart cambam ... but all plugins do dot appears in the plugin menu ; who are the missing ?
http://www.atelier-des-fougeres.fr/Cambam/Aide/Plugins/plugin_menu.html
After CB as started, have a look in the log window if there is an alert message about a plugin.
Re: Installing plugins - how to install plugins
« Reply #2 on: January 19, 2017, 18:03:12 pm »
How to install plugins on Windows OS
A list of plugins can be found here;
or here;
http://www.cambam.co.uk/forum/index.php?topic=4269.0
Plugins are files with a dll file extension, e.g. HeightMapPlugin.dll
Because the forum rules forbid attaching dll files it is common practice to zip them up into an
archive file, e.g. HeightMapPlugin.zip
Some version of Windows include zip/unzip functionality but there are also 3rd party utilities
such as 7-Zip; http://www.7-zip.org
1. Download the required plugin zip file to your computer.
    Sometimes there are several versions so it's important to select the correct one.
    Some versions may be old ones that have been superseded or they may be designed
    for different versions of CamBam such as v0.9.8 or v1.0 etc.
2. Unzip the archive file to reveal the dll and possibly other files such as a pdf manual.
3. Move the dll into the CamBam plugins folder.
    examples of where to find the folder,
    On Windows XP: C:\Program Files\CamBam plus 0.9.8\plugins
    On Windows 7: C:\Program Files (x86)\CamBam plus 0.9.8\plugins
    On Windows 7: C:\Program Files (x86)\CamBam plus 1.0\plugins
    Check that the dll file is 'unblocked', read this thread;
     http://www.cambam.co.uk/forum/index.php?topic=6294.msg50090#msg50090
    If CamBam is running you may get an error that the dll cannot be copied, just close
    CamBam and retry.
4. Restart CamBam and the plugin should appear in the menu structure as indicated in the
    forum thread for that particular plugin, please check here;
« Last Edit: January 19, 2017, 18:21:46 pm by EddyCurrent »
