"""Created on Sun Nov 13 12:54:25 2016@author: DTalaiverThis script converts G83 instructions to grbl accepted G-code."""#drill parserimport Tkinter as tkimport tkFileDialog root = tk.Tk()root.withdraw()root.deiconify()root.lift()root.focus_force()root.withdraw()file_path = tkFileDialog.askopenfilename(parent=root)outfile = open(file_path[:-3]+'4grbl.nc', 'w')retractFeed = 'F20'clearHeight = '0.25'with open(file_path) as f: for line in f: content = line elements = content.split(" ") if elements[0] != "G83": #if its not G83 just pass it out outfile.write(content) else: #extract elements from command for q in range(0,len(elements)): if "X" in elements[q]: xCmd = elements[q] elif "Y" in elements[q]: yCmd = elements[q] elif "Z" in elements[q]: bottom = float(elements[q][1:]) elif "Q" in elements[q]: increment = float(elements[q][1:]) elif "R" in elements[q]: retract = (elements[q][1:]) elif "F" in elements[q]: plunge = elements[q] #begin pecking #go to position outfile.write('G0'+xCmd+yCmd+"\n") curDepth=0 outfile.write('G0Z0'+"\n") while (curDepth>bottom): curDepth=curDepth-increment if curDepth<=bottom: curDepth=bottom #plunge outfile.write('G1'+'Z'+str(curDepth)+plunge) #retract outfile.write('G1'+'Z'+retract+retractFeed+"\n") #pecking done outfile.write('G0Z'+clearHeight+"\n") outfile.close()
I didn't see a method to upload file, so I'm not sure what the preferred method for code sharing is. Its short so I hope a direct paste is OK.
