Author Topic: Revolved Extrude - new plugin  (Read 7900 times)
« on: November 16, 2016, 19:05:24 pm »
Following on from my Profile2Helix plugin, this similar idea produces a surface so that 3D MOPs can be applied to cut the shape.
The idea is to draw half of an object, similar to the lathe MOP, and it will be rotated around the left hand end of a polyline to produce a circular surface.
I've attached a simple cb file, just install the plugin, open the cb file, click one of the lines then run the plugin.
You should soon see how it can be used.
In the picture you can see the profile line I made in red and the surface it produced in green.
In some cases the facets face the wrong way but I'm working on that issue. - Fixed
Edit: sorry I forgot to attach the example cb file, just attached in now.
Edit: Version 2 attached
1. Fixed vertical walls showing inside out.
Edit: Version 2.1 attached
Please remove the old Profile2Surface.dll from the CamBam Plugins folder first
1. Renamed to "Revolved Extrude"
2. Moved for Plugins menu to;
Top menus           Draw->Surface->Revolved Extrude
Right click menu    Draw->Surface->Revolved Extrude
Edit: Version 3 attached
    Windows
    Linux
« Last Edit: January 09, 2017, 20:06:48 pm by EddyCurrent »
    • Cambam French Doc
Re: Profile2Surface - new plugin
« Reply #1 on: November 16, 2016, 21:00:39 pm »
Very nice addition !, thanks for this plugin  ;D
« Reply #2 on: November 16, 2016, 21:19:19 pm »
That profile reminds me of a ceiling moulding, perhaps you could sweep it out in a linear fashion and
do your own mouldings.
Re: Revolved Extrude - new plugin
« Reply #3 on: November 16, 2016, 21:30:00 pm »
Dave,
You could probably use CamBam 'Extrude' for that
« Last Edit: November 19, 2016, 12:16:28 pm by EddyCurrent »
« Reply #4 on: November 16, 2016, 21:35:10 pm »
I'll give it go tonight when I get home.
« Reply #5 on: November 17, 2016, 10:42:32 am »
New version added to first post.
The assumption is that you want to cut the inside of any surface generated, however on the first version walls that were truly vertical were inside out, this version fixes that.
Version1 surface is on the left, new version2 surface is on the right.
« Last Edit: November 19, 2016, 12:16:40 pm by EddyCurrent »
« Reply #6 on: November 17, 2016, 13:13:37 pm »
Nice, I like it, Eddy! Thanks.
« Reply #7 on: November 17, 2016, 14:11:24 pm »
Great work, Eddy! A rotational 3D object.
I just wonder whether you are the best programmer among woodworkers or the best woodworker among programmers. :)
« Reply #8 on: November 17, 2016, 14:48:47 pm »
Nice words thanks, but the answer is, somewhere in the middle of both.  ;D
And as time moves on, slowly sinking down both  :(
« Last Edit: November 19, 2016, 12:16:53 pm by EddyCurrent »
« Reply #9 on: November 17, 2016, 15:13:34 pm »
I think the name RevolvedExtrude would be more useful in helping people find it.  That's the term Solidworks uses.
I wonder if a RevolvedCut would also be possible.  For example, perform a standard extrude, and then cut part of it away.
« Reply #10 on: November 18, 2016, 14:33:46 pm »
Rename to "Revolved Extrude" as suggested, this sounds like a sensible idea.
New version 2.1 added to first post in this thread.
Also the menu items for this plugin have changed, see first post for details.
Source files added here.
« Last Edit: November 19, 2016, 12:17:24 pm by EddyCurrent »
« Reply #11 on: November 22, 2016, 15:13:52 pm »
Manual attached
« Reply #12 on: January 09, 2017, 20:07:17 pm »
Update attached to first post, version 3
    Windows
    Linux
« Reply #13 on: September 26, 2017, 17:32:43 pm »
I just tried this to fill a void in CamBam and realized it only seems to do 360 degrees.  Is it possible to set it up to do 180 degrees?  Or is there a way to split a surface in half in CamBam?
I would note I am using 098.
I notice you say only works with 1.0, but the David's plugin page shows 098.  Is that a different plugin?
« Last Edit: September 26, 2017, 17:40:03 pm by Bob La Londe »
Offline mannycnc1
« Reply #14 on: October 31, 2018, 17:48:08 pm »
I would like to know that to...
When trying to extract this plugin , I get "Jzip could not create the file "\\?\C:Program Files \Cambam.. etc...
Can someone tell me what am I doing wrong?
Thanks
