Author Topic: [Solved] V1.0 R9 Spline to polyline don't use spline>polyline tolerance setting  (Read 16935 times)
I just found a bug specific to V1.0 with splines
Spline to polyline tolerance setting seems to have no effect when converting spline to polyline.
(we need to change the Spline Curve Steps for the display to obtain more defined polyline)
except with a hight value for "Spline curve steep", the resulting polyline has no arc, only straight segments.
Edit
I added a bug report list on a web page, as for 0.9.8
http://www.cambam.co.uk/forum/index.php?topic=5314.msg41921#msg41921
« Last Edit: July 10, 2024, 21:55:11 pm by dh42 »
Seems it has been solved (it is prior to the GIT list, I found no feedback in "Wath's new")
Edit: I found the bug list I had created for V1, prior to the GIT ... and yes the bug was marked as solved ;)
http://www.atelier-des-fougeres.fr/Cambam/Aide_V1/Bug_report_V1.0.html
« Last Edit: July 10, 2024, 21:54:19 pm by dh42 »
