Author Topic: ALT + left mouse button, not work  (Read 4213 times)
Offline BR52
« on: January 16, 2017, 15:49:59 pm »
I bought a new 500GB hard disk (HDD), just to install Linux.
My installation is:
Linux Mint 18.1 Cinnamon 64-bit
CamBam1.0-mono-alpha12b-64bit
CamBam1.0-mono.system
While the ALT key down + left mouse button, it does not work.
             Not rotate the camera.
Re: ALT + left mouse button, not work
« Reply #1 on: January 16, 2017, 15:55:08 pm »
Hello Armando! :)
From the Linux Mint system menu navigate to Preferences > Windows
In the 'Behaviour' section, under 'Moving and Resizing Windows', change the 'Special key to move and resize windows' to '<Super>'
(Super is the Windows key)
You will need to close and reopen CamBam for this to take effect.
« Reply #2 on: January 16, 2017, 16:01:52 pm »
I'm using Linux Mint and can confirm that changing the preferences according to Andy works fine.
Offline SteveT
« Reply #3 on: January 16, 2017, 18:48:09 pm »
Ubuntu 16.04LTS 64bit, ALT + Left mouse button works after changing the settings as outlined in the download section.
Steve
Offline BR52
« Reply #4 on: January 16, 2017, 19:50:25 pm »
Hi Andy,
I configure as you said, works perfectly now!
I will do more tests.
Thank you very much.
« Last Edit: January 16, 2017, 19:56:53 pm by BR52 »
