Author Topic: First attempt to do 4 axis toolpaths from a 3D model  (Read 93677 times)
Re: First attempt to do 4 axis toolpaths from a 3D model
« Reply #15 on: March 20, 2017, 22:19:29 pm »
Hey, I understood that :)  And noted Polish books on the photo too
Offline papslab
« Reply #16 on: March 21, 2017, 09:06:15 am »
That is amazing! What was the source of the 3d model?
Hello.
The model is from grabcad or similar page. I don't remember.
Offline papslab
« Reply #17 on: March 21, 2017, 09:21:34 am »
Nice job !
So the unwrap/wrap works in real ? and not only in my mind  :D .. (not yet tested on the machine)
did you notice distortions compared to the original model ?
It works great.
A number of rotational step was 360. Unwrap model was 28MB. There were no visible distorsions.
I used 4mm tapered ball nose end mill. It's a little to large diameter.
Pawel
« Reply #18 on: March 21, 2017, 10:01:25 am »
Ok, nice, so I'll continue to work on this plugin (currently, doing the surfaces without to have to run other plugins)
« Reply #19 on: March 21, 2017, 11:25:01 am »
Well done, Pawel.
Fly, czytasz po polsku?  :D
« Reply #20 on: March 21, 2017, 15:09:12 pm »
With some effort and guessing.
Anyway these are Slavonic words, although far from the way we write and pronounce them in Bulgarian :)
« Reply #21 on: March 21, 2017, 16:39:01 pm »
Yep. :D
« Reply #22 on: March 30, 2017, 20:13:26 pm »
A new version of the script ; now it creates the 3D surface itself.
a plugin version will follow soon
« Reply #23 on: March 30, 2017, 21:11:39 pm »
Good effort  ;D it's amazing what can be put in a script.
Offline papslab
« Reply #24 on: April 02, 2017, 09:36:30 am »
Works ok
« Reply #25 on: April 02, 2017, 15:32:48 pm »
I stay surprised that it works  ;D ...
I see that your unrolled model is close to 250k triangles ! .. I assume it takes hours to calculate the unroll ?
Last night I do some job on the UI for the plugin (only the design, currently, code remain to add)
Thanks for the tests  ;)
« Last Edit: April 02, 2017, 15:36:25 pm by dh42 »
Offline karst.drenth
« Reply #26 on: April 02, 2017, 16:50:16 pm »
looks cool  8)  8)
« Reply #27 on: April 02, 2017, 22:40:14 pm »
I wonder why it works bad on the same model in inches .. (the venus, resized to inches)
It's like too small triangles (absolute values) are not detected.
Offline quoy25
  • carpe diem
    • forge, foundry, machining and other stuff
« Reply #28 on: April 18, 2017, 18:04:16 pm »
Very Nice and impressive tool !
i've started learning CATIA machining  to be able to use my 4 th axis for complex 3D milling , but i think here is the answer for my needs .
is it possible to use rought + finishing operations with this unwrap/wrap option ?
what i mean is unwrap a "cylindric" shape, make some rought and finishing operation ( wave rought + horizontal finishing for exemple) and then wrap the GCODE with CAMBAM WRAPPER ?
does someone test rought operations ?
thanks in advance
quoy
« Last Edit: April 18, 2017, 18:08:31 pm by quoy25 »
« Reply #29 on: April 18, 2017, 18:23:07 pm »
Yes, in fact it's exactly the same than using a 3D machining operation, except that you wrap the resulting GCode, so you can define rough and finish the same, and use as many 3d mop you want. (and also boundaries as for any 3D job)
« Last Edit: April 18, 2017, 18:28:05 pm by dh42 »
