Hello Geoff,
I downloaded version 1.04 which fixes the copy/paste of the slotter mop, but.....
I can now copy/paste, but when your post the code, the second mop g-code moves do not show up in the posted code. The copied mop is listed, but no code is produced.
This was tried on polylines and circles, so it is not geometry specific. I also put a separate mop between the two slotter mop's with the same affect.
Now the other issues I have come across....
One problem is when the tool width is the same as the slot width, it gives an error of "the tool width is greater that the specified slot", but still outputs the code of the first mop only.
Another problem is when I have the slot geometry drawn already (snap ring groove for example), I do not need to add a slot depth, since I have the geometry drawn already.
If I put a "0" in the slot depth, telling slotter to profile the geometry exactly as drawn, it shows error in the slot depth box, but still outputs the code correctly.
Windows 10 build 1803, CamBam version 1.0,
Here is the test .cb file and the post processor I am using, Thanks, Jim
