Author Topic: Broken Fonts  (Read 37681 times)
Broken Fonts
« on: July 20, 2007, 10:04:18 am »
I've just noticed there are certain fonts where the TTF curve extraction is failing for some characters in some fonts.  (see picture).
I am currently investigating the problem and will resolve this in the next release.
Offline Arie kabaalstra
  • why buy one, if you can build one?
    • DUMET Watches
Re: Broken Fonts
« Reply #1 on: July 20, 2007, 10:27:26 am »
since it doesn't seem to do that with all the fonts. it might be somthing with the font files...
i'm sure you dream up some solution.. ;)
Re: Broken Fonts
« Reply #2 on: July 20, 2007, 10:47:53 am »
CamBam beta 0.7 R7 is working OK.
It was an 'improvement' I made for beta 0.7 R8 that has caused it.
Just need to find what that 'improvement' was.
I'm on the case...
Re: Broken Fonts
« Reply #3 on: July 20, 2007, 11:23:32 am »
It was indeed a beta 0.7 R8 'improvement'.
The problem is only when displaying the text.
Machine operations based on the fonts work OK.  Converting the font to a polyline also works and it then displays correctly.
This has now been fixed in the development version.
