Author Topic: rounding up coordinates  (Read 4360 times)
Offline emlclcy
« on: May 24, 2017, 12:57:32 pm »
is it possible to round the coordinates of a polygon?
say the endpoints were on a 3 decimal place grid, can you round this to say a 2 decimal place grid?
thanks
carl
Re: rounding up coordinates
« Reply #1 on: May 24, 2017, 13:44:06 pm »
Carl,
I'm not 100% clear on your requirements but these come to mind,
This plugin works for polylines, http://www.atelier-des-fougeres.fr/Cambam/Aide/Plugins/polyround.html
Also have look at the CamBam menu, Tools->Options->Grid
Then this plugin, http://www.atelier-des-fougeres.fr/Cambam/Aide/Plugins/gridmanager.html
Offline emlclcy
« Reply #2 on: May 24, 2017, 13:55:01 pm »
Carl,
eddy, thats exactly what i want but i have the free old version which i guess will not support this pluggin.
I'm trying to read a complex dxf file into altium pcb but it keeps falling over. I cant try it on the evaluation version as it says pluggins are disabled and it won't save dxf.
If i sent you a very simple dxf, basically a 4 sided polygon, which fails in altium, would you be up for rounding it and sending me it back to see if it works?
carl
« Reply #3 on: May 24, 2017, 14:14:30 pm »
Just attach it to a post here, zip it if you want.
Offline emlclcy
« Reply #4 on: May 24, 2017, 14:25:55 pm »
thanks! here is a part of the design, can you round it to 2 decimal places metric please?
cheers
carl
« Reply #5 on: May 24, 2017, 14:28:47 pm »
Try that, I had to change the 'lines' to 'polylines'
Offline emlclcy
« Reply #6 on: May 24, 2017, 14:35:53 pm »
thanks for trying but it didn't work! i could query the line segments in altium and they were to two decimals so the conversion was all good.
Think it may be a bug in altium now
thanks ever so much for trying tho
« Reply #7 on: May 24, 2017, 14:47:41 pm »
Maybe it's the wrong version of dxf ?
I assume you did a search ?
this for example; https://electronics.stackexchange.com/questions/72779/importing-drawings-dxf-in-altium
« Last Edit: May 24, 2017, 14:52:17 pm by EddyCurrent »
Offline emlclcy
« Reply #8 on: May 24, 2017, 14:56:05 pm »
its not consistent. when i read the dxf (tried v12 upto 2007) some of the polygons convert ok, the error message on the polygons that it fails on says its a duplicate coordinate, thats what lead me to think it was to many decimal places from the source cad system the dxf file viewed with notepad show 16 decimal places!
« Reply #9 on: May 24, 2017, 15:06:03 pm »
Try these, it's just one polyline now
One is to 2 decimal places (ver 4), the other is to more (ver 3).
« Last Edit: May 24, 2017, 15:09:06 pm by EddyCurrent »
Offline emlclcy
« Reply #10 on: May 24, 2017, 15:21:22 pm »
no they didn't work either.
i have sent test-2.dxf to altium to see what they think
