Author Topic: Funny, but CamBam saved the day again !!!  (Read 5597 times)
Offline sibianul
« on: May 30, 2017, 07:40:31 am »
Today I wanted to try something I seen on Pinterest (a while ago) and loved immediately, I will make something similar, or at least try!!!
Now a few weeks I tried to find a way to convert google maps tiles to vector, but I wasn't so successful, and today I found a way, but not using Google, but openstreetmap.org instead. It has by default an export to SVG option :D Just perfect!
Than I tried to import the SVG file into Fusion360, I tried multiple times but it failed, after it showed up a part of the file it was loading continuously for minutes. Than I tried with CorelDraw .. the same it failed, it even didn't show any contour, just loading continuously. So I tried 2 quite complex softwares, I was wondering if it's my PC, when looking at the resources used it wasn't even close to full, the CPU (i7-4771) was at 30% while importing, the ram the same 6Gb used from 16Gb available.
As CamBam doesn't import SVG I tried an free online converter to save the SVG file in DXF format, all good, the file size increased from 8Mb to 19Mb.
You should watch this video :)
https://www.youtube.com/watch?v=o-SEfhSMH54
But I still had problems in the past with cambam, I download a 3D model of a mirror frame, I couldn't open it, but for simple dxf file CamBam seem to kick ass !!!! Well done !!!
Re: Funny, but CamBam saved the day again !!!
« Reply #1 on: May 30, 2017, 17:29:32 pm »
Wow!
That is a really impressive piece of work!
Its not the bat, its the guy swinging it.
« Reply #2 on: May 30, 2017, 19:35:54 pm »
« Last Edit: May 30, 2017, 19:38:22 pm by pixelmaker »
