Author Topic: UCCNC Post Processor  (Read 44409 times)
Offline hdvideo
« on: June 24, 2017, 15:19:24 pm »
I'd like to see a dedicated PP for UCCNC.  I read where some are using the Mach3 post, so maybe it's not really necessary. Does anyone know what possible conflicts there may be between the two?
Thanks,
Ed
Re: UCCNC Post Processor
« Reply #1 on: June 25, 2017, 11:50:09 am »
Hi Ed
Try the default PP first.
UCCNC has basic cam so if you have trouble copy theirs and modify a copy of the default PP here.
« Reply #2 on: June 25, 2017, 11:57:06 am »
Does the UCCNC user manual list all the various G and M codes the software will accept?
If so, that's a great starting-point for coming up with a full-custom PP.
Offline hdvideo
« Reply #3 on: June 25, 2017, 13:39:09 pm »
Thank you both for the prompt response to my question. I'll give the default PP a try.
Lloyd, the manual does list all supported codes, but I've never tried writing or modifying a PP. Always up for a new challenge though, so will look into it.
Regards,
Ed
« Reply #4 on: June 25, 2017, 17:50:55 pm »
Ed,
For the most part, 'ordinary' g-codes and M-codes are accepted 'as is' by most machines.  A few require special syntaxes, and the PP and post-build-processor features are fully-capable of accommodating those oddities.
About the only thing you'll probably have to 'customize' (if anything) is the initial M-code 'setup' sequences.
Even for many 'oddball' machines, that seems to be about it.
The 'default' PP and the Mach-3 PP are not great examples for someone wanting to do a 'full-custom' PP, because they revert to native CB defaults for almost everything.
But we have lots of examples on here, and among the users of PPs that have pretty-much EVERY command spelled-out.  And the 'help' files while in CB are IMMENSELY helpful.  The capabilities and range of features of the PPs are fully-discussed.
There are users here who believe that 'other' CAM software will be more-capable at accommodating weird, old, or obsolete machines or completely 'custom' uses of normal machines not supported by ordinary g-code and m-code.
Such is not my experience.  The flexible PP facility of CB makes it possible to support odd-ball machines NO other CAM will manage properly!
But... you do NOT have to be a 'programmer' to write your own post-processor.  The PP is just a set of 'rules', not program code.  You would need a little programming background (or at least willingness to learn) to write your own post-build-processor.  But there's ready help here for that, if you need it.
Offline subatomic
« Reply #5 on: July 23, 2018, 16:53:36 pm »
I didn't see anyone report back above...
Did anyone have luck using CamBam with UCCNC?
I'm thinking of trying UCCNC instead of Mach3...
Offline robertk925
« Reply #6 on: July 23, 2018, 23:36:45 pm »
I use Cambam with UCCNC almost every day and have had no issues, although my machining is pretty simple (primarily 2.5D shapes, no tool changer). I highly recommend UCCNC over Mach 3/4.
« Reply #7 on: July 23, 2018, 23:45:27 pm »
OK, Robert!  The first thing we MUST ask, is "what PP do you use?"
If you have a 'custom' one for UCCNC, please post it, if you have not, already!  If you have, please link us to the post.
We're all here to help one-another make better use of this soft!
Yours,
Offline robertk925
« Reply #8 on: July 26, 2018, 03:53:42 am »
Hi Lloyd:
I use the Mach3 PP and have had no issues so far.
-Robert
« Reply #9 on: October 30, 2024, 20:26:49 pm »
An UCCNC post pro
It is basically the same as default PP, I just add the PP name in the header.
