Author Topic: vb and C#  (Read 54211 times)
Re: vb and C#
« Reply #30 on: June 29, 2017, 00:47:10 am »
Yeah... unless he's willing to "open up", I think I am too.
And I HATE that!  We try to help, then folks won't let us!
Offline BR52
Re: vb and C#
« Reply #31 on: June 29, 2017, 04:01:02 am »
Hello Alderanuri,
One thing I get angry and hate is people who creates software and rents out per month.
The person are restricted!
I know you want to be free from these people.
http://www.mozaiksoftware.com/products/mozaik-cnc
Offline Alderanuri
draw rectangle
« Reply #32 on: June 29, 2017, 19:35:47 pm »
hi
how to draw rectangle
and selected tool
visual studio code_?
Re: vb and C#
« Reply #33 on: June 29, 2017, 19:56:10 pm »
<sigh>... Alderan (???), just select the rectangle tool, click one corner, drag, then click the other.  You can size it with the cursor, and correct the size and origin to your likes in the drawing item's description!
Re: vb and C#
« Reply #34 on: June 29, 2017, 20:01:07 pm »
In VB
sub main
        Dim pr As PolyRectangle = New PolyRectangle()
        pr.CornerRadius = 0
        pr.Width = 100
        pr.Height = 50
        pr.Closed = True
        pr.Update()
        CamBamUI.MainUI.ActiveView.CADFile.Add(pr)
end sub
Offline Alderanuri
Re: vb and C#
« Reply #35 on: June 29, 2017, 20:33:14 pm »
Attribute VB_Name = "Model001"
Public Sub Model_001()
App.New
Dim drw As Drawing
Set drw = App.ActiveDrawing
Dim Ty As MillData
Set Ty = App.CreateMillData
heigth = 800
width  = 450
Dim Rectangle As Path
Set Rectangle = drw.CreateRectangle(0, 0, width, heigth)
Rectangle.Fillet (5)
    App.SelectTool T1
        Rectangle.Selected = True
    With Ty
    .ToolNumber = 1
    .OffsetNumber = 1
    .SpindleSpeed = 18000
    .DownFeed = 3000
    .CutFeed = 8000
    .SafeRapidLevel = 30
    .RapidDownTo = 30
    .MaterialTop = 0
    .Stock = 0
    .FinalDepth = -5
    .NumberOfCuts = 1
    .McComp = acamCompTOOLCEN
    .XYCorners = acamCornersSTRAIGHT
    .WidthOfCut = 1
    End With
    Ty.RoughFinish
Rectangle.Selected = Fale
End Sub
Re: vb and C#
« Reply #36 on: June 29, 2017, 20:47:03 pm »
That does not looks like a Cambam code  ???
Re: vb and C#
« Reply #37 on: June 29, 2017, 20:47:12 pm »
AH!  Terrific!  We're progressing.
Now... we'll have to know a FEW things about your machine, but most of that is pretty clear.  All you (seem to) want is a CB script that will draw a rectangle for you!
To be true, you don't NEED a script to do that, because CB has a very versatile rectangle ability.  And there are even plugins to improve it.
But if you want a script to draw rectangles in CB, there are already examples, and we CAN help you.
Thanks Alderan... now it begins to make sense to me.
Re: vb and C#
« Reply #38 on: June 29, 2017, 20:48:21 pm »
Oh, David, that's NOT CB code, that's code for his existing CAM.  He wants to do the same thing in CB!
Re: vb and C#
« Reply #39 on: June 29, 2017, 20:54:36 pm »
Ah ! ok  ::)
So the code for a rectangle is in the previous message, and for the rest, I assume it's a machining operation that is added.
there is a document about how to create a new MOP here. (Vb and Python)
http://www.cambam.info/ref/script.mop-automate
Offline Alderanuri
Re: vb and C#
« Reply #40 on: June 29, 2017, 20:56:17 pm »
Now I expect samples from you
Offline Alderanuri
Re: vb and C#
« Reply #41 on: June 29, 2017, 20:58:32 pm »
Sub Main
        Dim pr As poliRectangle = New PolyRectangle ()
        pr.CornerRadius = 0
        pr.Width = 100
        pr.Height = 50
        pr.Closed = True
        pr.Update ()
        CamBamUI.MainUI.ActiveView.CADFile.Add (pr)
end sub
tool selected ?
« Last Edit: June 29, 2017, 21:02:09 pm by Alderanuri »
Re: vb and C#
« Reply #42 on: June 29, 2017, 21:11:07 pm »
I never creates code myself that creates machining operation (MOP) so I can't help about that, but certainly you can find infos by reading the source code of plugins that creates MOP.
There is no doc about programing for CB, so the only way is to explore the source code that users share on this forum  and to explore the cambam .dll with a tool like Reflector, ILspy, or the visual studio facilities ; it's what I do (I'm a noob coder)
Offline Alderanuri
Re: vb and C#
« Reply #43 on: June 30, 2017, 20:29:11 pm »
No progress
Sample and API incompleteness
Re: vb and C#
« Reply #44 on: June 30, 2017, 20:40:03 pm »
No progress
The API is incomplete, that is correct and that will not change any time soon.
No progress because you have to look at the code examples of plugins here; http://www.atelier-des-fougeres.fr/Cambam/Aide/Plugins/plugin_menu.html
and work it out for yourself, that is what everyone else had to do.
Now paste this reply into here; http://imtranslator.net/translation/english/to-turkish/translation/
« Last Edit: June 30, 2017, 20:43:06 pm by EddyCurrent »
