Today I fell on a problem that seems related to snappy plugin, CB give an error when opening the file, but strangely, the problem appears ONLY if the file is loaded from its project icon, if loaded through the file menu, no problem. If I remove the snappy plugin, the error disappears.
All snap features in snappy are disabled except "snap to object".
I attach the file that give this error.
Win7 64 bits, CamBam 1.0 32 bits
edit: I just see it is the same problem reported by geoffrey, (file is 30Mb) .. if snap to object is disabled the problem go away too ...
edit2 ... and the problem do not appears all the time ... just after I writed this post, the problem as disappeared .. and I change nothing in the file
seems it appears one in two launch ...
