Author Topic: "Snappy", more snap points for CamBam plugin  (Read 161633 times)
Re: "Snappy", more snap points for CamBam plugin
« Reply #15 on: August 27, 2017, 20:06:58 pm »
Yes, my system is still XP for the shop.  I don't know (yet) how to rectify the problem.
Eddy,
Thanks!
« Reply #16 on: August 27, 2017, 20:18:25 pm »
I'll test it on my old PC ;)
« Reply #17 on: August 27, 2017, 20:28:01 pm »
tested with V1 and V0.98 on XP Pro SP3, no problems, works on both
On the XP machine, the Cambam help/about say that the net framework is V 2.0.50727.3655 (2.0.50727.8669 on W7 - 64)
what say CB about your frameworks ?
« Reply #18 on: August 27, 2017, 20:35:18 pm »
help/about WHERE, David?  I was on the control panel looking at my installs.
My CB help/about reports "Framework Version : 2.0.50727.8761", and that's a later version than what seems to be required!
I'm running .Net Framework 3.5, which is supposed to contain ALL of V2.0...
« Last Edit: August 27, 2017, 20:38:57 pm by lloydsp »
« Reply #19 on: August 27, 2017, 20:49:30 pm »
A "show snaps" option would be really cool.
« Reply #20 on: August 27, 2017, 21:34:42 pm »
The one in Cambam.
Yep, it's the case, and the plugin use .Net Framework 2.0 (3.5 seems always to appears as 2.0)
« Reply #21 on: August 27, 2017, 21:38:10 pm »
So???  I'm confused.
I'm running the version of .NET that should support that application, yet it says it was compiled on a "more recent version" than what I'm running now. (???)
Lloy
« Reply #22 on: August 27, 2017, 21:56:35 pm »
I don't know why it do not works ... it should works !  ??? (my 3.5 net frameworks on XP is older as yours, and that works)
Offline tau
« Reply #23 on: August 27, 2017, 22:08:10 pm »
Eddy,
thx for further clarifying what should be seen on my screen, but unfortunately even though i have created all the geometric entities you've shown on your screenshot and the fact that 'snap to objects' is selected, i can't see any snap points highlighted ony my screen.  ???
Even tried disabling and enabling again the 'snap to objects' flag under the 'View' Menu item. Still no visible snap points. ::)
My CB About Dialog says i have Framework Version : 2.0.50727.8762 installed.
Thx,  Tunc
« Reply #24 on: August 27, 2017, 22:12:20 pm »
Snap points are not visible ; The mouse sticks (magnet) on the points when passing over it, exactly as with the built-in snap points.
« Last Edit: August 27, 2017, 22:47:16 pm by dh42 »
« Reply #25 on: August 27, 2017, 22:38:56 pm »
Re
@Tau: I just add a small video on the website ;)
http://www.atelier-des-fougeres.fr/Cambam/Aide/Plugins/Snappy.html
« Reply #26 on: August 27, 2017, 23:49:12 pm »
And, just to be clear, both snappy and 'additional snap points' work fine on my 1.0V... but I can't USE 1.0, because of so many incompatibilities with my files.
« Reply #27 on: August 27, 2017, 23:54:08 pm »
On the same PC ?
« Reply #28 on: August 27, 2017, 23:56:13 pm »
Suggestion for an addition.  If two circles or arcs are selected, create snap points for a line tangent to both.
« Reply #29 on: August 28, 2017, 00:01:35 am »
Already exists in Draw/plus/tangente ;)
http://www.atelier-des-fougeres.fr/Cambam/Aide/cad/Entities.htm#plus
