Author Topic: [V1-19] - losing object references after layer deletion and undo (solved in RC1)  (Read 11449 times)
Offline jk
If layer with objects is deleted and restored back via undo, mops don't see these objects anymore.
How to reproduce:
open the attached file, generate the toolpaths and see all is ok.
now delete the layer 0, generate the toolpaths - mops lose the objects and obviously complain.
restore back the layer via ctrl+z, generate the toolpaths - mops still complain though shouldn't.
now put two new polylines on layer 0. the second one will have id == 2. now we have two objects with the same id !
« Last Edit: November 01, 2019, 21:56:56 pm by dh42 »
Re: CB 1.0r15 - losing object references after layer deletion and undo
« Reply #1 on: September 06, 2018, 17:34:46 pm »
Tried on R16 on Windows ; as for you, after restoring the layer, toolpath are not generated (but the right IDs are still in the MOP ID property) and a warning is displayed in the log windows
If I add a new geometry, I get a correct ID (ID = 1 in this case) but not with a second (#2 as one existing object)
If I undo, the (wrong) geometry #2 is removed as expected .. and now, if I generate toolpath, that works ...
« Last Edit: September 06, 2018, 17:38:06 pm by dh42 »
Offline jk
« Reply #2 on: September 06, 2018, 18:24:03 pm »
... and if we do save and reload file after the undo, objects are correctly referenced again.
« Reply #3 on: September 09, 2018, 14:17:52 pm »
I've noticed a number of times in both 098 and 1.0 that when a CB session becomes unstable you can often recover and continue if you save, close, restart, and reopen.
