Author Topic: post processors problem  (Read 2224 times)
Offline Sjinkie
« on: December 28, 2018, 13:32:13 pm »
Hi im  Sjinkie  from the netherlands im new here.
i try to use cambam on my cnc machine i tryed to use a postprocessor made by someone of the forum bud i can't upload it in my list of prosessors
can anyone help me
sjinkie
Re: post processors problem
« Reply #1 on: December 28, 2018, 14:15:53 pm »
The path for post processors on my system is this;
CamBam v1.0
C:\ProgramData\CamBam plus 1.0\post
CamBam v0.9.8
C:\ProgramData\CamBam plus 0.9.8\post
Just copy the post processor file into the 'post' folder, the file type should be .cbpp
You then MUST restart CamBam for it to appear in the list.
If you ever need to modify a .cbpp file ALWAYS make a copy of the original file first then modify the copy and rename it.
« Last Edit: December 28, 2018, 14:22:37 pm by EddyCurrent »
« Reply #2 on: December 28, 2018, 20:48:34 pm »
Because mostly, the folder is an hidden folder, the easiest way to access to the right one is to use the Tools/Browse system folder menu in CamBam to find the right place. Then you are able to copy the .cbpp file in the Post folder.
Offline Sjinkie
« Reply #3 on: December 29, 2018, 11:11:03 am »
thanks for the fast answer it helped me a loth
but now i have a error that he  can find the .vbs file  i have the  file on my computer but problebly not on the right map
sjinkie
« Reply #4 on: December 29, 2018, 11:19:51 am »
It sounds like that should be in the CamBam 'scripts' folder.
C:\ProgramData\CamBam plus 1.0\scripts
or
C:\ProgramData\CamBam plus 0.9.8\scripts
Which post processor and .vbs files are you using ?
« Last Edit: December 29, 2018, 11:21:58 am by EddyCurrent »
Offline Sjinkie
« Reply #5 on: December 29, 2018, 12:01:23 pm »
that is what i thought to  so i had the file already in that map
i try to use the heidehain tnc151b from the forum
im not sure if it will work becasue my cnc machine is with the heidehain tnc 128
sjinkie
Offline StefanR.
« Reply #6 on: December 29, 2018, 14:32:02 pm »
Hi Sjinky,
Try setting the .vbs script directly in C:/
« Reply #7 on: December 29, 2018, 15:12:17 pm »
Yes, now I see it's a post build script it goes to whatever path you put in the post processor parameters.
You can see from the attached picture that it has been set to C:\
I asume you changed the .txt extension to .vbs
For sake of neatness the .vbs file should probably go in the 'post' folder and the path updated in the .cbpp file to match.
« Last Edit: December 29, 2018, 16:41:39 pm by EddyCurrent »
Offline Sjinkie
« Reply #8 on: January 02, 2019, 12:56:37 pm »
thanks guys  for the help that is fixed now.
now I have a really long list of gcodes and when I upload that to the machine with usb stick
I got some errors on the gcodes  on the machine
I tried to upload photos bud that didn't  worked yet
sjinkie
