Author Topic: [V1 -26] Point List Nesting (solved in V1 RC1)  (Read 10731 times)
« on: January 14, 2019, 22:58:53 pm »
Often with 1.0 when I double click the field for the point list ID and select the point list from the tree it doesn't enter the value.  If I go back and type in the point list id it does enter the value.
« Last Edit: November 01, 2019, 22:13:35 pm by dh42 »
Re: Point List Nesting
« Reply #1 on: January 15, 2019, 02:58:42 am »
If the behavior is the same that on mine, when you click on the points in the drawing area, the ID is not immediately visible in the nesting property and we must click again on the part name to refresh and for the ID to appears.
https://www.screencast.com/t/kt6Z7dWXw
If I select the point list in the tree, I never get the ID it in the nesting property, as you.
Same problem on both 0.98 and 1.0
« Last Edit: January 15, 2019, 03:03:06 am by dh42 »
« Reply #2 on: January 15, 2019, 08:33:39 am »
Same with me. Thought it's a problem with MS Forms and .NET so I either select from the screen or enter ID(s) manually.
« Reply #3 on: January 15, 2019, 15:24:18 pm »
Often the point list in my work lays along another geometry feature.  It can make it difficult to pickup from the drawing.  I wind up entering the value manually.
« Reply #4 on: January 15, 2019, 16:06:43 pm »
Since I don't have Adobe Flashplayer installed your screencasts will not play, is there a setting at your end to overcome this ?
« Reply #5 on: January 15, 2019, 19:56:01 pm »
One other method I sometimes use is to select objects from the layer tree and drag them with the mouse onto the MOP name. CB asks whether this is what I want to do and after confirming the objects are assigned to the MOP.
« Reply #6 on: January 15, 2019, 20:25:55 pm »
The same here..
« Reply #7 on: January 15, 2019, 21:28:16 pm »
Guy's, You can play David's clip if you unblock flash in chrome.
Edit: forgot to add Chrome has it's own version of Flash so unless you have uninstalled that you still have it.
« Last Edit: January 15, 2019, 22:07:52 pm by dave benson »
« Reply #8 on: January 16, 2019, 01:06:34 am »
No, I think flash player is needed for this video format (and I'm not able to change it)
