Author Topic: Insert spindle speed as Qx  (Read 1618 times)
Offline Mark81
« on: February 23, 2019, 12:57:18 pm »
My new machine controller has a dedicated laser macro: M10 Qx, where x is the PWM settings 0..255.
I usually set the spindle speed to decide the power of my laser for each MOP, but now I need to place this value after Q, instead of S like $s would do.
I didn't find anything in the post-processor documentation. Is it possible to do it?
Re: Insert spindle speed as Qx
« Reply #1 on: February 23, 2019, 14:58:37 pm »
Yup, but I'll be tied up with a legal matter for three or four hours.  If someone else doesn't get back to you on it, I'll describe how later.
« Reply #2 on: February 24, 2019, 01:51:00 am »
Just try this:
Instead of <$spindle><$s>, try,
Q<$s)
Offline Mark81
« Reply #3 on: February 24, 2019, 08:20:40 am »
Q<$s)
Unfortunately, It says "Unexpected token '<' at line 5" and it exports it literally in the g-code.
« Reply #4 on: February 24, 2019, 09:17:52 am »
I think Lloyd made a typo and meant this;
{$spindle} Q{$s}
Unfortunately the $s macro also adds an 'S' character in front of the speed number which produces;
e.g. QS1000
It looks like a post build processor is required to change the S into Q
« Last Edit: February 24, 2019, 09:30:46 am by EddyCurrent »
Offline Mark81
« Reply #5 on: February 24, 2019, 09:32:39 am »
Hi Eddy,
yer, perhaps my question wasn't so clear. I meant exactly how to rid the 'S' char that {$s} prints out.
"It looks like a post build processor is required to change the S into Q". Is something built-in in CamBam or I have to write my own? It's just to understand, because it's something very easy to do in any programming language.
Right now I ended up with just:
M10 {$s}
and than I replace "M10 S" with "M10 Q".
Offline Mark81
« Reply #6 on: February 24, 2019, 10:04:07 am »
Done.
I've just wrote a simple application "PostBuildReplace":
https://drive.google.com/open?id=18-zrTLDg-J6_aVBenjyifkNjAngwNqIn
It needs three arguments: "filename" "before" "after".
Here what it does:
  • opens the "filename" file
  • reads the contents and replace "before" with "after"
  • writes again the same file with the new contents
You have to configure CamBam PP as follow:
Post-Build Command: path/to/PostBuildReplace.exe
Post-Build Command Args: "{$outfile}" "M10 S" "M10 Q"
That's it.
Extremely simple, without much error handling (it just checks if you passed 3 args and if it cannot open the file exits), but it does what I need. Right now it reads all the content in RAM. For very big files it will be better to read line-by-line, replace and write in another file. I will do it next time :-)
« Last Edit: February 24, 2019, 10:05:48 am by Mark81 »
Offline Mark81
« Reply #7 on: February 24, 2019, 10:31:01 am »
Ok this version does what I suggested above:
https://drive.google.com/open?id=1xTIyz7675QnDEGTWkdNaPO2GnbfBkU3N
« Reply #8 on: February 24, 2019, 10:43:34 am »
Excellent job !
