Hi
I have Centos7 up to date running CamBam alpha16 64bit and if I start it up and select the text icon at the top it closes. There is a message in /var/log/messages "System.DllNotFoundException: /home/jamby/opt/CamBam1.0a16/libcambam64.so"
If I run the Plugin "Arc Text" a save current file window opens. By selecting cancel and then when selecting the text icon at the top I get the same window asking about closing the file. But on the second attempt to select the text icon at the top a window opens that allows to type in text but no fonts can be selected. But hitting okay in that window will cause the save current file window again.
I have tried launching from the command line in the directory where CamBam is and have executed the LD_LIBRARY_PATH and export commands from the command line and checked with the "env" command to see that its there. I have edited both the CamBam.CAD.dll.config & CamBam.exe.config with the hard path to CamBam. Using /home/jamby/opt/CamBam1.0a16/libcambam64.so and ~/opt/CamBam1.0a16/libcambam64.so and ./libcambam64.so
Mono JIT compiler version 4.6.2 (Stable 4.6.2.16/ac9e222 Mon Jul 31 05:33:23 UTC 2017)
Copyright (C) 2002-2014 Novell, Inc, Xamarin Inc and Contributors.
www.mono-project.com TLS: __thread
SIGSEGV: altstack
Notifications: epoll
Architecture: amd64
Disabled: none
Misc: softdebug
LLVM: supported, not enabled.
GC: sgen
CamBam plus [1.0] Rel 16 Linux
Copyright © 2018 HexRay Ltd
CamBam.CAD : 1.0.6753.24057
CamBam : 1.0.6753.24059
Build Date : 6/28/2018 2:21:54 PM
uname -a Linux tri 3.10.0-957.5.1.el7.x86_64 #1 SMP Fri Feb 1 14:54:57 UTC 2019 x86_64 x86_64 x86_64 GNU/Linux
ls -al -rwxr-xr-x. 1 jamby jamby 47904 Jun 28 2018 libcambam64.so
Any help with this problem is welcome
Thanks
Jim
