Author Topic: Properties treeview behavior  (Read 1361 times)
Offline Mark81
« on: April 15, 2019, 05:23:16 am »
I don't know if this is already possible or already requested, but it would be useful to avoid collapsing the nodes of the treeview while navigating among items or MOPs. Instead it should kept in the very same position (of course if the current visible items are still available in the next selection).
Example:
1. create two MOPs (say two Profile)
2. select the first one and expand the "Lead In Move" node
3. now select the other MOP
The node is now collapsed and under some circumstances the treeview changes also its position.
To compare the two sections you have to manually find and open again the node.
When comparing a lot of MOPs (or even items, i.e. the Center node for Circles) it's very annoying!
Offline dwc
    • corson.ch
Re: Properties treeview behavior
« Reply #1 on: April 15, 2019, 17:54:36 pm »
+1
« Reply #2 on: April 15, 2019, 20:30:05 pm »
I always thought it would be handy to have an option for a split tree.  (Before anybody goes berzerk, I said OPTION.)  Geometry on one side and operations on the other.
