Author Topic: V-ENGRAVE Problem sur texte  (Read 762 times)
Offline CLAUDESAINT
« on: May 13, 2019, 07:45:03 am »
Bonjour,
J'ai rencontré un probleme lorsque j'utilise V-engrave sur du texte notament sur certaine lettres ou chiffres.
En fait sur les lettres et chiffres qui sont "plein" style : 0 9 8 6 A R O P Q D B ....
sur une texte horizontal pas de probleme, mais des que l'on incline le texte ca ne marche plus.
voir image avec parcours d'outil
Salutation
Re: V-ENGRAVE Problem sur texte
« Reply #1 on: May 13, 2019, 08:34:43 am »
1. Select the inclined text
2. From the menu, Edit->Explode
3. This will make some "'Regions"
4. Add the Regions to a V-Engrave Machining Operation (Mop)
cb file attached.
« Last Edit: May 13, 2019, 09:14:26 am by EddyCurrent »
Offline CLAUDESAINT
« Reply #2 on: May 14, 2019, 15:14:54 pm »
Thank you, it works
But Just a small remark, the tool stroke is not very clean for the "0".
see the attached file
Salutation
« Reply #3 on: May 14, 2019, 20:26:54 pm »
I did some engraving myself last week and I also had trouble with the "O" but it was not really noticeable once cut.
« Reply #4 on: May 14, 2019, 23:16:03 pm »
Some trick to solve the problem you show with text.
Play with the resolution value in the V-engrave plugin. (mostly, smaller values)
Change the value for the text to polyline conversion in the option (CB must be restarted) to obtain a more detailed polyline when the text is converted to polyline (manually or when a text object is used in a mop)
this change act only on the text, so if you already have converted the text to polyline/regions, it has no effect and you must redo the "explode text"
and the last chance is to use a "remove arcs" on the polylines(*) so the polyline contains only small straight segments and no arcs ; this works better with V-engrave
(*) explode the regions before, then when polyline are converted with no arcs, redo the regions (ctrl i)
« Last Edit: May 14, 2019, 23:21:59 pm by dh42 »
