Author Topic: How to access program part information via a plugin programmatically  (Read 2238 times)
Offline MrJTJinx
I'm pondering over producing an operation list from a job.  The all the information required is in the part submenu where the operations are listed followed by the relevant feeds speeds and tooling for each operation.  I propose writing a plugin which will extract this information and make it printable on an A4 sheet.
Any suggestions would be most helpful.
Are you proposing to write the plugin yourself ?
The plugin will involve some work on finding the appropriate C# "libraries" but in the UNOX world there are many "simple programs" that could take a csv file, or another simple "file format" and print or convert it in PDF, some of them are very easy to use and exist some ports even for the "Windows" or "Mac" world.
Carlo D.
Maybe this script can help to get parts/mops informations
http://www.cambam.co.uk/forum/index.php?topic=6902.0
Offline StefanR.
The tooling table is the easy part, use {$tooltable} in your post. Perhaps its also a good start point for the script. It's macro already goes through all MOP's to extract the tooling used.
Offline MrJTJinx
Thanks David,
Eddy, Yes I was going to try and write something, I have noticed that its hard to encourage others who code to like peoples ideas and run with them to improve cambam.  Sadly i'm becoming disillusioned.  Over the last two years i have seen very few additional plugins and certainly no updates i can remember. I imagine most users have jumped on the Fusion360 band wagon, that's all well and good until Autodesk gets us all hooked and reliant and then starts to charge per month.  All i ask is if you like ideas you see other users come up with that you assist to the betterment of cambam for all.  Tried sprutcam, 10 coffees and as many hours, i lost interest due to its complexity.  Only pleased i tried a friends version - purchasing would have been a sever drop of a learning curve.
My programming skills are pretty basic so don't be expecting an all singing and dancing plugin.
Just because i don't own a Haas does not mean that i don't have inspirations of being professional.
The aim is to produce a job schedule so i can print out the operations and tools list and as i progress through the tool chain and load the code onto my machine, i don't have to start going back to look at cambam or the NC job file to remind myself what tools and operations i was going to perform.
Thanks for you suggestions and help so far, i will be trying my best to read through it and see if i can produce anything to report back for constructive criticism.
"Over the last two years i have seen very few additional plugins and certainly no updates i can remember."
That's just not true.  Our authors here contribute new or updated plugins regularly.
2 years of plugins. (and remember that plugins are made by users, not by Andy)
http://www.cambam.co.uk/forum/index.php?topic=4886.180
24 new plugins added and even more updated and enhanced. (and one that is not yet in the website ; I must do the web page and translation)
and the latest CB version is dated: V1 R16 - Build Date : 27/06/2018 (help/about)
« Last Edit: May 14, 2019, 22:39:32 pm by dh42 »
... and, I don't see a reason to complain about that.
