Author Topic: Can't see some plugins  (Read 1927 times)
Offline rheine
« on: May 19, 2019, 15:30:27 pm »
Windows 64/7
Licensed 9.8
Can't see threading or Lathe.
Both dlls are not blocked.
Also cut viewer gives me file not found.
Re: Can't see some plugins
« Reply #1 on: May 19, 2019, 16:43:48 pm »
You did look under the "Machining" menu tab rather than "Plugins" ?
« Reply #2 on: May 19, 2019, 20:24:58 pm »
If you have the plugins in the right folder then right click on the plugin file and follow the steps to unblock it.
Its a Windows thing usually.  Not a CamBam thing.
CutViewer is not included with CamBam.  Its a third party application and I believe the author has passed away.  Last I heard it was no-longer available.
Offline rheine
« Reply #3 on: May 19, 2019, 20:55:58 pm »
EddyCurrent,  bingo!  I'm good. Thank you.
