A LONG time ago, I added the 'print' plugin. But it does a crappy job in terms of resolution.
If I need a higher-resolution image captured from the CB drawing screen, I use the utility "MWSNAP". It's a fairly versatile image-capture method that will print to whatever the system default printer was when MWSNAP was started. You cannot change printers during a run of the utility, because it 'reads' what the printer is upon starting-up, and not again during the run. You must close MWSNAP, change the printer, then re-start the utility.
You-all may have other methods you use, and I'd be interested in hearing about them, too.
