Author Topic: Post-processor for NCStudio 5.5.60 ?  (Read 2355 times)
Offline bartwaw
« on: September 13, 2019, 10:40:48 am »
i'm trying to run it on my friends machine that has NCstudio (5.5.60) controller.
For now without success.
Maybe someone is working on such controller ?
Re: Post-processor for NCStudio 5.5.60 ?
« Reply #1 on: September 13, 2019, 11:08:17 am »
Bart,
There are a lot of good post-processor writers here.  If you could upload or point us to the programming info for it, I'm sure you'd get some help.
Offline bartwaw
« Reply #2 on: September 13, 2019, 14:23:58 pm »
Found problem with post-processor.
Changed G81 in settings from:
{$g81} {$_x} {$_y} {$_z} {$r} {$_f}
to
{$g81} {$x} {$y} {$_z} {$r} {$_f}
I't looks that NCstudio need all coordinates. As I suppose, "_" instructs cambam to not generate coordinate when not changed.
Am I right ?
Now must find how to change post-processor that NCStudio will accept feed rates.
For now it cuts at full speed, feedrates must be changed manually.
« Last Edit: September 13, 2019, 14:29:52 pm by bartwaw »
« Reply #3 on: September 13, 2019, 14:41:17 pm »
Does NCStudio not accept G0 and G1 commands? I've seen it only on one large flatbed router used for cutting and grooving  sheets of Al-Plastic-Al sandwich sheets used for building decoration. It mimics the way Canadian AXYZ routers work for the same purpose and they have some "slang" of G-code of their own. Bu still, they do accept G0 and G1.
« Reply #4 on: September 13, 2019, 14:44:06 pm »
Here you can read and save NCStudio programming manual. No matter rhe version they should have similar functionality.
http://doc.weihong.com.cn:8880/NcStudio%20Programming%20Manual-R6.1.pdf
« Reply #5 on: September 13, 2019, 15:45:24 pm »
I haven't read the whole manual, but went over the commands it accepts.  It looks pretty 'generic'.  It has some Weihong-specific commands, but the basic set is the same as most generic NC machines.
Almost any very-simple post-processor should work.  What are you trying that gives you 'no luck'?
Offline bartwaw
« Reply #6 on: September 13, 2019, 16:05:07 pm »
I'm already analyzing that manual.
Previously G81, G82 and G83 were generated by cambam in some places without X or Y.
NCStudio as i suppose need X and Y in G81.
I've changed as i said to:
« Reply #7 on: September 14, 2019, 01:13:26 am »
Yes, the "default" one seems to be the closest (better that mach3 pp)
It seems also that G61/64 are missing in NCstudio GCode. (exact stop/constant velocity)
remove the {$velocitymode} macro in the post processor header to remove the output of G61/64
if you find a {$arccentermode} macro in the PP you're using, remove it too.
« Last Edit: September 14, 2019, 01:18:00 am by dh42 »
Offline bartwaw
« Reply #8 on: September 14, 2019, 05:39:43 am »
removed  {$velocitymode}
This is how it looks. Will try today this PP.
  <PostFile>{$comment}NCStudio_post {$endcomment}
{$header}
{$mops}
{$footer}
</PostFile>
  <Header>{$comment} {$cbfile.name} {$date} {$endcomment}
{$tooltable}
{$cbfile.header}
{$units} {$distancemode} {$cuttercomp(off)}
{$toolchange(first)}
{$clearance}
</Header>
  <Footer>{$clearance}
{$spindle(off)}
{$endrewind}
{$cbfile.footer}
</Footer>
  <ToolTableItem>{$comment} Frez-mm-: {$tool.diameter} {$endcomment}
{$comment} T{$tool.index}  {$endcomment}</ToolTableItem>
  <ToolChange>{$clearance}
{$comment} {$tool.diameter} {$endcomment}
</ToolChange>
  <MOP>{$comment} {$mop.name} {$endcomment}
{$workplane}
{$mop.header}
{$spindle} {$s}
{$blocks}
{$mop.footer}
</MOP>
  <EndRewind>G91
G0 Z10
G0
G4 P2
G0 X0 Y0
M30</EndRewind>
  <Rapid>{$g0} {$_x} {$_y} {$_z} {$_f} {$_a} {$_b} {$_c}</Rapid>
  <FeedMove>{$g1} {$_x} {$_y} {$_z} {$_f} {$_a} {$_b} {$_c}</FeedMove>
  <ArcCW>{$g2} {$_x} {$_y} {$_z} {$i} {$j} {$k} {$_f}</ArcCW>
  <ArcCCW>{$g3} {$_x} {$_y} {$_z} {$i} {$j} {$k} {$_f}</ArcCCW>
  <Drill>{$g81} {$x} {$y} {$_z} {$r} {$_f}</Drill>
  <DrillDwell>{$g82} {$x} {$y} {$z} {$r} {$p} {$_f}</DrillDwell>
  <DrillPeck>{$g83} {$x} {$y} {$z} {$r} {$q} {$_f}</DrillPeck>
  <NumberFormat>0.###</NumberFormat>
  <MaximumArcRadius>10000</MaximumArcRadius>
  <SuppressParserErrors>true</SuppressParserErrors>
  <AddLineNumbers>true</AddLineNumbers>
</PostProcessor>
« Reply #9 on: October 23, 2019, 18:42:32 pm »
Some news about this post processor ? Is it working now ?
If it is, it would be fine if you can share it ;)
