Author Topic: 1.0 RC3 Entering a dimension mathimatically only works on whole numbers.--Bug?  (Read 833 times)
Offline ChrisCTS
I drew a rectangle, and wanted to center it by dividing the width by 2. this works with whole numbers, But
if I try typing 138.2/2  then  NaN is the result, but 138/2 works fine. the same happens for the width or height dimension as well as setting the lower left values. I had never noticed this before, Earlier version ( But I'm not sure I have used a fractional number before)
Is this by design or is it a bug?
Same on CB 0.98
I think that the ability to use the "/" is only to write fractional inches values like 1/2, 3/8, etc ... and not to do maths in the textbox.
If you try something like 2*10, it do not work too, so no math allowed in fact ... not a bug.
It looks like it works with fractions only and 138.2/2 is not a fraction.
Offline gmoo
  • Jam it !
Did you also try deviding by 2.0 ?
That doesn't work either because fractions should contain integers only.
Math within a data entry field is a wonderful thing that I use all the time in SolidWorks.  Visual Cadd had it and Rhino I think has it now.
Offline gmoo
  • Jam it !
QCAD also. Like it very much !
