Thanks Bubba, if you ever have the need to tap a few holes on your router then you could, with this gearbox
and a 425 0z/in motor tap up to 1/2 inch 13 all day long, After Tapping those 18 M6 holes in a row I
felt the gearbox and servomotor and they were cold. I originally was going to attach the tapping unit to
the side of my spindle, But after temporarily lashing it to the spindle and checking how much working area
I would lose I decided to put it directly over the top of the spindle and directly couple it, and I put the
spindle mount on slots so that it can be disengaged easily which works well.
Eddy for your purposes drilling holes or pockets in wood then the general purpose Drilling cycles would
be good G81 or G83, or spiral milling like you do,which saves toolchanges, I do this sometimes in steel and Aluminium
when the tolerance allows, if however you need a very accurately positioned deep hole that is actually round and does not
deviate from perpendicular,then you need to drill and ream the hole with a canned cycle like the ones shown
in the Hass video "what the aim of the game" is to evacuate the chips out of the hole, because if you don't
then they contribute to the hole being maybe oversize, out of round, and or deviate from a straight path
somewhat like a directional boring rig, the deeper the hole the more trouble will you have.
There are a couple of pics of the Hybrid Tufting machine I made, to show you what I'm going to do with the plugin.
The first pic is some of the components of the machine, the transparent part shows to holes that intersect at an
acute angle, one hole holds a hook the other is for a grub screw to secure the hook.
Those holes 46 of them must be straight and evenly spaced, for example in the old money a 1 thou cumulative error
on the holes means the last hole would be 45 thou out of place, and you've just made a doorstop.
The holes in the blocks are both ten times the diameter of the drill deep.
with a hole this deep and a 2.5 mm drill bit, your feeds and speeds must be
adhered to very closely just slightly to much feed and the drill will bend a little
and hole position will deviate and of course you must get the chips out of the hole.
Another thing about this job is that you have to tap the hole, and a broken Tap is almost a sure thing if the
intersection where the two holes meet is off a little, I broke a few this way until I wised up, and now I inspect
hole intersection with a bright light.
I use the plugin to make a drilling cycle that rapids to the stock surface and evacuates the chips consistently
and at the intersection where the two holes meet I slow the plunge feedrate down to half speed to stop
the cutting edges on the drill bit from destroying themselves, if you don't do this they don't last long. Maybe 10 or 15 holes and they only good for general purpose work whereas with the
custom canned cycle they last two blocks 92 holes even with all these precautions they are not perfect though, but in the practical world good enough to work
The other thing on this particular job it saves 4 hours machining time as compared to
the regular G81/83's
I've always hand tapped the grub screw holes so being able to do it in the mill is
a godsend.
