Author Topic: drilling  (Read 1575 times)
Offline hana
Re: drilling
« Reply #15 on: January 14, 2020, 18:27:35 pm »
Hey!  Terrific Hana!  I was just the first guy to jump in with a suggestion.  You'll find this to be the MOST helpful technical site on the internet.  In fact, I'm seldom the person who offers a suggestion, because so many people help.
I am sooo happy I found you people!! I went through so many pages on internet, manuals and have so many information...but! nothing helps with the PROBLEM :)
I am sure I will be often here!!  :o Fighting with Mach at the moment.
Lloyd,  do you have any idea why I cannot change number of velocity parameter?
Online Dragonfly
Re: drilling
« Reply #16 on: January 14, 2020, 19:44:02 pm »
"Lloyd, I did exactly gcode upon your instructions (set peck distance) and it works!!!!  Cheesy I was so proud about myself, jumping here yesterday  Grin Big help, thanks!!"
What version of Windows?  Could it be permissions to write/modify files?
If you install Mach3 again you have to run all the setup process again, assigning pins, tuning motors, inputs and so on. It's not plug-and-play system.
Offline hana
Re: drilling
« Reply #17 on: January 14, 2020, 21:08:36 pm »
I know, scary for me. I don't want to, that is the reason I am trying to find the problem without installing all over!!
I'll try Windows, no idea, maybe!! Thanks!!
Re: drilling
« Reply #18 on: January 14, 2020, 21:27:50 pm »
Still not able to change number of velocity. Even hitting enter. It drops to 0 and cannot change it anywhere else after. Any idea? If I install Mach again, takes origin numbers and these are to high again.
I would suggest to lower your machine speed in about 10% increments. Mach3 will let you do this if you change the to even number (from my experience) no decimal point. Hit enter and the hit save settings button. It will do its thing by adding a decimal values on its own.. See the picture, I entered 100 and mach3 adjusted it. ;) :D ;D
Re: drilling
« Reply #19 on: January 14, 2020, 21:39:11 pm »
On my machine, that use an external motion controller (ESS), the values can be changed ONLY if the motion controller is connected to the PC ; in other cases, the values are turned to 0 if I try to change them.
Offline hana
Re: drilling
« Reply #20 on: January 14, 2020, 21:53:13 pm »
I have tried different numbers increase, but dropping to 0. Maybe David is right, I am not connected to machine (drilling), must wait. But I remember the same problem even connected. Month ago.. Maybe I was doing wrong something else. I will try to connect other computer to see what happen!!
Re: drilling
« Reply #21 on: January 15, 2020, 01:04:12 am »
Hmmm, David, in my previous post with the screen snap what you see is capture done of my home pc that is not connected to anything.. Machine is 90 yards away in shop. ;) :D ;D ;D
Re: drilling
« Reply #22 on: January 15, 2020, 02:11:49 am »
Yes but maybe you've at least the // port installed ?
On mine there no // port installed (Win 64 bits), only the ESS plugin (but no ESS connected)
Without // port installed, there is also other things that are not working, like the Hotkey emulation for the inputs ...
« Last Edit: January 15, 2020, 02:23:51 am by dh42 »
Re: drilling
« Reply #23 on: January 15, 2020, 11:51:56 am »
David, what version of Mach3 you trying to do this on? I'm using  Version R3.043.062.
Offline hana
Re: drilling
« Reply #24 on: January 15, 2020, 22:42:11 pm »
Hello, problem solved again!! THANKS!!
I had to be connected to machine, EVERY number enter, save AND restart Mach.  ::)
But, super speed is in normal and I am celebrating again!  ;D
Re: drilling
« Reply #25 on: January 15, 2020, 23:22:27 pm »
The same ;)
Offline nifty1a
Re: drilling
« Reply #26 on: January 20, 2020, 22:59:09 pm »
I found that I had to click the axis button first before changing values, including the X-axis button, if the X-axis graph is showing.
