Author Topic: CamBam 1.0 is now the official production release  (Read 68661 times)
Re: CamBam 1.0 is now the official production release
« Reply #15 on: March 27, 2020, 21:21:17 pm »
Unfortunately, there is a lot that I can't convert because they are done with a more recent version of my visual studio installation (2010) ; I'm trying to update to community 2017 ... and for others the sources are not available.
« Last Edit: March 27, 2020, 21:41:17 pm by dh42 »
« Reply #16 on: March 27, 2020, 21:46:44 pm »
Can you make a list of all that need fixing ?
Time for bed here but I will try to recompile some tomorrow, they may be a way for the ones we do not have source for.
« Last Edit: March 27, 2020, 21:51:37 pm by EddyCurrent »
« Reply #17 on: March 28, 2020, 00:35:15 am »
Hello Eddy
I just install VS2017 ... and it can load the jk source code on github, I just "convert" cb2cm and also test that the plugin works on both 32 and 64 bits.
I hope I'll be able to convert all for who I found source code.
almost the same as your currently, with some fix
aligner.dll FIXED
Centroid.dll FIXED
EntityCounter.dll - no source found FIXED
ExportSelectionToDXF.dll FIXED
extender.dll - source found FIXED
File Cleaner.dll - no source found FIXED
FileMerge.dll - no source found (I've only old one) FIXED
geolink.dll - no source found FIXED
RadiusPlugin.dll FIXED
Randomize.dll - seems I forgot it in the web page .. no source found
relocator.dll - source found FIXED
Texturize.dll - no source found
trochomops.dll - no source found
VEngrave_Plugin.dll FIXED
ViewToolbarAddins.dll - yours with the zoom ; no source found FIXED
simulate with camotics 1.5.1.0 FIXED
Collision detector - no source found FIXED
Script launcher V1.0 (for CB 1) - no source found FIXED
Break Edges - no source found
I'll update this list when converted or if I find source.
« Last Edit: March 28, 2020, 21:24:43 pm by dh42 »
« Reply #18 on: March 28, 2020, 06:28:15 am »
Updated plugin for CamBam 64 bit. ;  EntityCounter v2.1
Updated plugin for CamBam 64 bit. ;  FileMerge v1.6
Updated plugin for CamBam 64 bit. ;  ViewToolbarAddins v2.7
Updated plugin for CamBam 64 bit. ;  Geolink v1.2.2
Can't fix "Texturize" or "Randomize" the author confuscated them.
@Dave Benson
Dave can you please recompile "File Cleaner" , "Collision Detector" and "Break Edges" for CamBam 64bit
« Last Edit: March 28, 2020, 07:43:21 am by EddyCurrent »
« Reply #19 on: March 28, 2020, 07:57:24 am »
Hi Eddy
Here you go.
I've zipped up 7 of the ones I need.
cb2cm--->camotics
collision Detector
File Cleaner
OnMassMopEditor
trochmops
Vengrave
Wrapper
I have some more and will post then if nobody else does them.
« Reply #20 on: March 28, 2020, 08:57:30 am »
Updated plugin for CamBam 64 bit. ;   ScriptLauncher v1.1
Offline MrJTJinx
« Reply #21 on: March 28, 2020, 10:01:13 am »
Thanks guys for all your work.
I have spent time recently overhauling the Acme screws and replacing them for Ball screws with anti backlash nuts.  My old Elliott milling machine is back working as a CNC again.  Although i have reluctantly upgraded to windows 10 (what a mistake) and had to replace/reinstall softwre to have everything compatible and 64 bit, I have not yet messed with my Cambam build.  I will sit back and wait a few months befor taking on another mind melt, im sure by then you guys will have fixed all the plugins and dlls.
Looking forwrd to hearing about new features
Please keep damn good care of yourselves and stay well
all the best
Jason
« Reply #22 on: March 28, 2020, 21:41:28 pm »
Ok web site updated
http://www.cambam.co.uk/forum/index.php?topic=4886.msg67460#msg67460
Currently I've not added the trochomop because it's an older version (2.2) the latest is 2.4 ... Dave or Eddy, do you have the latest sources ? ... if not I'll add the 2.2 for only 64 bit and keep the 2.4 for 32 bits.
@dave: I can't find the post about OnMassMopEditor on the forum, can you point it out for me please ? ... maybe the post have another name ?
I don't change the wrapper because the previous version is working on CB 64 bits.
« Reply #23 on: March 28, 2020, 21:46:08 pm »
trochomop 2.4 is here; https://github.com/jkmnt/matmill/releases
I tried to recompile but could not see how to reference the "Triangle" code.
« Reply #24 on: March 28, 2020, 22:16:47 pm »
Ah ... too complex for me !!!
I'll add the 2.2 until JK come back ;)
edit: done
Break Edges remain to do and I think that we have all major plugins working ...
« Last Edit: March 28, 2020, 22:43:57 pm by dh42 »
« Reply #25 on: March 29, 2020, 03:01:31 am »
Hi David
I'll do break edges when I've fixed up the X64 version of CB.
It's running on my X64 Laptop but very slowly 20 seconds between selecting a entity
and it turning red and control handed back to me, during this time I get the whirling circle
of boredom and the screen becomes opaque and flashes. maybe it's a driver issue.
I repaired the installation at first, then re-installed completely without any plugins and still no joy.
the plugins are running at full speed just stuff in the drawing space seems to slow things down.
« Reply #26 on: March 29, 2020, 03:33:18 am »
Hello Dave  ;)
Ah !!
What Andy said me by mail
I think some of the odd slow down errors seen on Windows 10 are windows update related - very frustrating, - hopefully the x64 version may be another option if this happens ?!
In this case it's maybe the 32 bits version the option for you  ;D ...
« Reply #27 on: March 29, 2020, 09:44:31 am »
Hi Dave,
I am sorry to hear you are still having this problem.   ???
I hate doing the 'blame it on a windows update excuse'.
I actually had this same problem on a (previously working fine) old I5 windows 10 laptop, so I spent a lot of time investigating.  Even weirder, a release app launched through visual studio worked fine but same problems you described when run normally.  A few months later I went back to that machine and everything was working fine again.
In my case, it didn't appear to be a driver issue.  :-\
Does the 32 bit version work OK on you laptop?
« Reply #28 on: March 29, 2020, 11:11:39 am »
David, it's here;
http://www.cambam.co.uk/forum/index.php?topic=7856.msg62892#msg62892
« Reply #29 on: March 29, 2020, 11:42:11 am »
Hi Andy
I'm not worried that the X64 version is playing up, It's installed on a laptop that I specifically bought to do the development work on my AI tool changers and only has Visual Studio,Wireshark and Hantec Oscilloscope software installed on it.
I installed CB on it only to test the X64 plugins, on the other hand if my trusty Win7 32 bit CB version went down I would show those girls at a Robbie Williams concert how to do hysteria properly.
I surfed this website and tried a few things found in the threads here but no joy.
I tried compatibility mode with win 8 and it seemed to be a little faster.
while it was running in this mode and after a while I got to draw a circle, and then clicked off it until it was de-selected and then  clicked back on it.
What I noticed was that the property panel for the circle dia,position ect, updated immediately then after maybe 10 seconds the circle became selected in the drawing view and then after a further 10-15 seconds the circle in the layer tree hi-lighted and became active.
I did check to see if dot net 3.5 was enabled and it was, but with two of the options turned off
so tomorrow I'll try with those options turned on, and if no joy then I'll install CB1.0 32bit and report the result.
David I have worked on the OnMassMopEditor plugin and added more values in the mops that can be changed
so wait a bit and I'll post the new one later sometime later this week.
« Last Edit: March 29, 2020, 11:45:34 am by dave benson »
