Author Topic: Surface3d, a part is missing  (Read 1386 times)
Offline webmax
« on: June 05, 2020, 18:48:01 pm »
Hi,
I'm using Cambam Plus 1.0 and I have a problem with a specific file.
I do 2 3d surfaces on a specific STL (one for roughing another for finishing) and both operations are ignoring a part of the STL.
I opened the STL in blender and everything seems normal (faces with no more than 3 vertices, no non manifold parts, ect...)
Do you have any idea?
As the file is too large to be added with this post, here is a link to it
http://www.maxsoft.be/cambam/bug-3dsurface.cb
Thanks,
Regards,
Webmax
« Last Edit: June 05, 2020, 18:52:13 pm by webmax »
Re: Surface3d, a part is missing
« Reply #1 on: June 05, 2020, 19:25:50 pm »
This link don't work  ;)
« Reply #2 on: June 05, 2020, 19:29:36 pm »
Bubba, the link works for me.
The part you highlight is below 1mm in Z height but you set the "Target Depth" to 1mm which means the section is never reached.
Surface_Z = 0.99999737739563
Change "Target Depth" to that number and it works as expected.
If you want to know how to find that Z height, use this plugin; http://www.atelier-des-fougeres.fr/Cambam/Aide/Plugins/FindZ.html
« Last Edit: June 05, 2020, 20:48:17 pm by EddyCurrent »
Offline webmax
« Reply #3 on: June 06, 2020, 04:58:12 am »
Thanks a lot for the reply!
Enjoy your week-end.
Webmax
« Reply #4 on: June 06, 2020, 12:13:11 pm »
Hmm, thats what I'm getting.
