Author Topic: Would not install plugins - Net Framework - CAS - Sandboxed  (Read 536 times)
Offline n4jee
Same problem 2 different computers:
Error loading plugin c:\Prog(x86)\cambam plus 1.0\plugins\  cambam.cadsoliss.dll  and GRBL machine plugin.dll
message:
An attempt to load an assembly from a network location which would version of Net Framework caused the assembly to be sandboxed in previous versions of net framework. This release of the net framework does not enable CAS policy by default. So this load may be dangerous. If this...Ran out of screen.
I'n running the latest version of net framework. I had cambam with the GRBL plugin previously loaded on this computer, but needed a clean install for troubleshooting another problem.
Offline n4jee
Re: Would not install plugins - Net Framework - CAS - Sandboxed
« Reply #2 on: June 29, 2020, 02:40:58 am »
Thanks, that did the trick.
Gene
