Author Topic: Will plug-ins not work with the demo version?  (Read 239 times)
Offline pthien
« on: July 27, 2020, 21:04:51 pm »
I'm a new user evaluating Cambam, so I have an unlicensed version of Cambam.
I've tried loading loading two different plugins.  One is "GRBL Machine" and the other is a display plugin that is supposed to show an additional toolbar for changing display.  But neither of these seem to be recognized after a restart of Cambam.
This is my plugins folder (below).  Am I doing something wrong?  Maybe these won't work until I have a licensed version?
Thanks in advance for any help.
 Volume in drive C has no label.
 Volume Serial Number is E41F-ACE8
 Directory of C:\Program Files (x86)\CamBam plus 1.0\plugins
07/27/2020  03:50 PM    <DIR>          .
07/27/2020  03:50 PM    <DIR>          ..
07/27/2020  03:50 PM            47,104 CamBam.CAD.Solids.dll
02/29/2020  11:15 PM            26,240 CamBamLathe.dll
02/29/2020  12:52 AM            25,088 CamBamPlus_Toolkit.dll
02/29/2020  11:15 PM            25,216 ExcellonIO.dll
07/27/2020  03:50 PM           285,184 GRBLMachinePlugin.dll
03/09/2013  03:55 PM            11,241 HeightMapPlugin-Src.zip
02/29/2020  11:15 PM            34,432 HeightMapPlugin.dll
07/26/2020  10:34 AM             6,144 ViewToolbarAddins.dll
               8 File(s)        460,649 bytes
               2 Dir(s)  61,451,431,936 bytes free
C:\Program Files (x86)\CamBam plus 1.0\plugins>
Re: Will plug-ins not work with the demo version?
« Reply #1 on: July 27, 2020, 21:18:54 pm »
Plugins should works with the demo version if the evaluation period is not over (40 uses). When the evaluation period is over, plugins and scripts are disabled, the DXF export is disabled and the max number of lines of GCode is limited to 1000 lines.
It may be another problem ; have a look here.
https://cambamcnc.com/forum/index.php?topic=6294.msg50090/index.php#msg50090
« Last Edit: July 27, 2020, 21:28:22 pm by dh42 »
Offline pthien
« Reply #2 on: July 27, 2020, 21:28:02 pm »
Thank you again, David, that did the trick!
