Author Topic: Error after installing V Engrave  (Read 614 times)
Offline miklstel
« on: August 06, 2020, 14:21:06 pm »
Just installed V Engrave plug-in.  I get this error when I try to save.
Re: Error after installing V Engrave
« Reply #1 on: August 06, 2020, 14:22:34 pm »
Please give more infos !
What version of cambam, what version of the plugin, Linux or Windows ?
« Reply #2 on: August 06, 2020, 14:53:01 pm »
seems that you get this error if you are using the V-engrave plugin for CB 0.98 with CB V1.0
bee sure you downloaded the right version of the plugin ;)
http://www.atelier-des-fougeres.fr/Cambam/Aide/Plugins/Vengrave.html
Offline miklstel
« Reply #3 on: August 06, 2020, 15:06:46 pm »
You are so correct.  I reinstalled the correct version and now it works.  Thanks so much.
Mike
« Reply #4 on: August 06, 2020, 15:09:33 pm »
OK, have fun ;)
Offline llaves
« Reply #5 on: December 31, 2020, 17:37:07 pm »
I'm having the same problem.
On starting CamBam I get an error
Error loading plugin C:\Program Files [x86]\CamBam plus 1.0\plugins\Engrave_Plugin;dll
Exception has been thrown by the target of the invocation.
I downloaded a clean copy of Vengrave for 1.0 32bit
Cambam Plus 1.0
Win 10 64 bit
