Author Topic: importing dxf not respect layers  (Read 1759 times)
Offline nicolas
« on: October 05, 2020, 15:02:15 pm »
Hi,
I'm surprising that my last .dxf is not imported correctly: shapes are not in the right layer and all layers are green.
I done dxf with qcad, and I can read it with correct layer's color in LibreOfficeWriter! But not with Cambam.
With old version if this file, I havn't problem.
I havn't change nothing to my Windows10-64, nothing to my CamBam 1.0.7364.41821.
Is somebody can help me please?
The file (reduced) is attached.
Best
Re: importing dxf not respect layers
« Reply #1 on: October 05, 2020, 15:20:32 pm »
Your DXF format is too recent (AC1027, ACad 2013 to 2017) use the Autocad R12 / R13 or 2000 format to save your DXF.
http://www.cambam.info/doc/dw/1.0.0/file-menu.html
Autodesk DXF files - up to AutoCAD 2000 format (*.dxf)
Offline nicolas
« Reply #2 on: October 05, 2020, 15:43:28 pm »
Thank you.
I saved it in R13, R14, pb is not solved. In R12 version, it's ok. Thanks a lot.
Is there a way to check in wich version a dxf file is saved?
Best
« Reply #3 on: October 05, 2020, 15:48:28 pm »
Yes, open the DXF with a text editor a search for a line like ACxxxx where xxxx is the version (in the line 8 on your file)
https://knowledge.autodesk.com/support/autocad/learn-explore/caas/sfdcarticles/sfdcarticles/drawing-version-codes-for-autocad.html
Offline nicolas
« Reply #4 on: October 05, 2020, 15:58:17 pm »
Okay.
Interesting to note that the problem disapears with newer version, In AC1027, no pb ...
thanks a lot again
« Reply #5 on: October 05, 2020, 16:09:57 pm »
 :) How react DXF formats are often a mystery !!
I use ACAD 2000/2002 most of the time (AC1015)
Offline ThisAmplifierIsLoud
  • Jam it !
« Reply #6 on: October 06, 2020, 20:11:50 pm »
Same here : https://cambamcnc.com/forum/index.php?topic=8115.0
very strange, very strange...
in between I found out :
 "greening" happens often after renaming layers
repair :
load greened file into qcad
select layer 0
draw a line and remove it
wait approx. 10-15 seconds
now overwrite file using "save as"
Maybe you'll need 2 or 3 tries.
Very strange behaviour... very strange...
best regards
Bernhard
Offline nicolas
« Reply #7 on: October 09, 2020, 06:33:19 am »
Ok, very strange, yes, but now solved  :) . Thanks a lot.
