Author Topic: inside / outside ignored - result is always inside ?!?  (Read 1340 times)
Offline ThisAmplifierIsLoud
  • Jam it !
« on: November 19, 2020, 17:03:23 pm »
Dear CAMBAM - Jedis,
what´s wrong with that polyline ?
Wanted to mill it outside, but result is always inside.
Bug, feature or dummie in front of the screen ?
Best regards
Bernhard
best regards
Bernhard
  • Jam it !
Re: inside / outside ignored - result is always inside ?!?
« Reply #1 on: November 19, 2020, 17:07:50 pm »
The solution is ... dummie in front of the screen.
Found a duplicated line.
Best regards, keep on drinking !
Bernhard
best regards
Bernhard
« Reply #2 on: November 19, 2020, 17:10:15 pm »
Good for you, Bernhard!
All the 'expert' help in the world may get you past a problem, but solving it yourself teaches you something you'll not easily forget!
Offline tau
« Reply #3 on: November 19, 2020, 17:13:25 pm »
Bernhard,
this seems to be another solution for your cambam file:
- select profile and explode
- then join all lines with 0.1 tolerance
- set polyline attribute Closed to "true"
and then it will also machine the outside.
« Reply #4 on: November 19, 2020, 17:14:45 pm »
For me, this is not the problem ; the problem is that your polyline(1) is not closed (see the Closed property) ... just set Closed to True and it will works ;)
But you're right, there is also a small duplicated line, but CamBam can do with it if you juste close the polyline.
« Last Edit: November 19, 2020, 17:17:11 pm by dh42 »
