Home
Downloads
Forum
Shop
News:
Home
Help
Search
Login
Register
CamBam
Resources
CamBam files (*.cb)
Door Number
« previous
next »
Print
Pages: [
1
Author
Topic: Door Number (Read 22922 times)
SteveT
Storm Trooper
Door Number
on:
November 23, 2020, 21:22:03 pm »
Hi, Created this for our French house the Dragon is a Welsh Dragon, plan to engrave it on to a polished brass plate the Dragon will be filled with red wax and the rest black.
Logged
EddyCurrent
CNC Jedi
Re: Door Number
Reply #1 on:
November 23, 2020, 21:36:01 pm »
The number 2 has a rather uneven flow, try using, Edit->Polyline->Arc fit, with a value of 0.8 for a start and see how that looks.
Yes, the dragon must be red
What depth will you engrave to ? it's always a guess for me to decide that.
Last Edit: November 23, 2020, 21:39:18 pm by EddyCurrent
Logged
SteveT
Storm Trooper
Re: Door Number
Reply #2 on:
November 23, 2020, 21:55:57 pm »
Hi Eddy, The edit polyline worked a treat
The Dragon and Name is 0.3 mm and the Number will be 0.5 mm all machined with a 45 deg carbide cutter.
I have cut a trial one in a bit of laminate flooring and very pleased with the dragon and name and now the number will be great.
Logged
EddyCurrent
CNC Jedi
Re: Door Number
Reply #3 on:
November 23, 2020, 22:14:13 pm »
I suppose depth of cut is limited by the cutter angle and hence width of cut.
Logged
SteveT
Storm Trooper
Re: Door Number
Reply #4 on:
November 24, 2020, 11:55:37 am »
Yes Eddy its a bit of a balance between depth and width go to deep and you lose the fine detail as with the Dragon so I have 0.3 mm for the fine detail and 0.5 mm to make the number more defined
Logged
Print
Pages: [
1
« previous
next »
CamBam
Resources
CamBam files (*.cb)
Door Number
