Yes you are quite correct LLoyd.
You see about a year ago when I first got my big laser, I recall visiting a ebay shop were they were
selling glass lenses claiming more power because they had a shorter focal length, so after
posting here I went and found the shop and they say that there lens is better because it has a focal length
of 2.3 mm against the standard 4 mm focal length. but the idea of going the other way was just an aberration.
So that left me with the dilemma of what to do, I had worked out from my test tile results and
the input power of my laser (don't know the output power) so I hope everything is linear.
Anyway the abacus popped out 1.8 watts for 0 to 225, so 2 watt's is what i need and
this is not surprising really as that is what a lot of the ebay offerings are.
I looked at a 2 watt laser module and could get one for $70 and I could swap it out with the 15 watt
when needed but this still required me using the mill which is too slow for lasing and I use it for a lot for other
things, so today I bought a $200 dollar 650 mm x 500 mm 2 watt, the laser mount fit's my big laser too
so I can use it as well.
I'll just sit in the corner of the shop and let it run, if doing imaging then it's going to take time.
